I hope for help, I have been trying for hours to install new nodes without any result
2022-04-17T12:39:16.045Z Install : node-red-dashboard 3.1.6
2022-04-17T12:39:16.086Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-dashboard@3.1.6
2022-04-17T12:39:16.854Z [err] npm
2022-04-17T12:39:16.855Z [err]
2022-04-17T12:39:16.855Z [err] ERR!
2022-04-17T12:39:16.855Z [err] code
2022-04-17T12:39:16.855Z [err] ENOTSUP
2022-04-17T12:39:16.856Z [err] npm
2022-04-17T12:39:16.856Z [err] ERR!
2022-04-17T12:39:16.856Z [err] notsup
2022-04-17T12:39:16.856Z [err] Unsupported engine for node-red-dashboard@3.1.6: wanted: {"node":">=12"} (current: {"node":"10.19.0","npm":"6.14.4"})
2022-04-17T12:39:16.856Z [err] Not compatible with your version of node/npm: node-red-dashboard@3.1.6
2022-04-17T12:39:16.857Z [err]
2022-04-17T12:39:16.857Z [err] ERR!
2022-04-17T12:39:16.857Z [err] notsup
2022-04-17T12:39:16.857Z [err] Not compatible with your version of node/npm: node-red-dashboard@3.1.6
2022-04-17T12:39:16.857Z [err] npm
2022-04-17T12:39:16.857Z [err] Required: {"node":">=12"}
2022-04-17T12:39:16.857Z [err] Actual: {"npm":"6.14.4","node":"10.19.0"}
2022-04-17T12:39:16.860Z [err]
2022-04-17T12:39:16.860Z [err] npm
2022-04-17T12:39:16.860Z [err] ERR!
2022-04-17T12:39:16.860Z [err] A complete log of this run can be found in:
2022-04-17T12:39:16.860Z [err] /root/.npm/_logs/2022-04-17T12_39_16_858Z-debug.log
2022-04-17T12:39:16.869Z rc=1
2022-04-17T12:46:11.156Z Install : node-red-dashboard 3.1.6
2022-04-17T12:46:11.200Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-dashboard@3.1.6
2022-04-17T12:46:12.756Z [err] npm
2022-04-17T12:46:12.756Z [err] ERR!
2022-04-17T12:46:12.756Z [err] code
2022-04-17T12:46:12.756Z [err] ENOTSUP
2022-04-17T12:46:12.757Z [err] npm
2022-04-17T12:46:12.757Z [err] ERR!
2022-04-17T12:46:12.757Z [err] notsup
2022-04-17T12:46:12.757Z [err] Unsupported engine for node-red-dashboard@3.1.6: wanted: {"node":">=12"} (current: {"node":"10.19.0","npm":"6.14.4"})
2022-04-17T12:46:12.758Z [err] npm
2022-04-17T12:46:12.758Z [err] ERR!
2022-04-17T12:46:12.758Z [err] notsup
2022-04-17T12:46:12.758Z [err] Not compatible with your version of node/npm: node-red-dashboard@3.1.6
2022-04-17T12:46:12.758Z [err] Required: {"node":">=12"}
2022-04-17T12:46:12.758Z [err] Actual: {"npm":"6.14.4","node":"10.19.0"}
2022-04-17T12:46:12.761Z [err]
2022-04-17T12:46:12.761Z [err] npm
2022-04-17T12:46:12.762Z [err] ERR!
2022-04-17T12:46:12.762Z [err] A complete log of this run can be found in:
2022-04-17T12:46:12.762Z [err] npm
2022-04-17T12:46:12.762Z [err] /root/.npm/_logs/2022-04-17T12_46_12_759Z-debug.log
2022-04-17T12:46:12.769Z rc=1
It is quite clear. You have the wrong version of Node.js installed. You are trying to use Node.js v10 which is out of support and isn't supported by Node-RED. Please install Node.js v16 which is the current long-term supported release.
