Hello and welcome to the forum.
Your question is not really Node-Red specific... but more of a "How program a thing in javascript"
There are many options out there that can easily be put in a function node.
https://www.google.com/search?q=javascript+timer+hours+minutes+seconds
And then there are many timer nodes available. Search for timer in the palette for one that might work for your needs.
I have a function I found online that I use to calculate downtime duration. I eliminated seconds from it because I didn't need it for my purposes.
In my case, I have a Pi running Node Red at each of our machines that reads PLC data and saves it to a MySQL db at our central status display. When a machine has an error, the Pi creates a timestamp using the function getDateTime() and saves that to the database. The central display sees that timestamp, gets the current date and time and calls the function timeDiffCalc(Now, Last_Update) to create a string to display the downtime.
I hope this helps.
Chris
function getDateTime() {
var now = new Date();
var year = now.getFullYear();
var month = now.getMonth()+1;
var day = now.getDate();
var hour = now.getHours();
var minute = now.getMinutes();
var second = now.getSeconds();
if(month.toString().length == 1) {
month = '0'+month;
if(day.toString().length == 1) {
day = '0'+day;
if(hour.toString().length == 1) {
hour = '0'+hour;
if(minute.toString().length == 1) {
minute = '0'+minute;
if(second.toString().length == 1) {
second = '0'+second;
var dateTime = year + '-' + month + '-' + day + ' ' + hour + ':' + minute;
return dateTime;
function timeDiffCalc(Now, Last_Update) {
let diffInMilliSeconds = Math.abs(Now - Last_Update) / 1000;
// calculate days
const days = Math.floor(diffInMilliSeconds / 86400);
diffInMilliSeconds -= days * 86400;
console.log('calculated days', days);
// calculate hours
const hours = Math.floor(diffInMilliSeconds / 3600) % 24;
diffInMilliSeconds -= hours * 3600;
console.log('calculated hours', hours);
// calculate minutes
const minutes = Math.floor(diffInMilliSeconds / 60) % 60;
diffInMilliSeconds -= minutes * 60;
console.log('minutes', minutes);
let difference = '';
if (days > 0) {
difference += (days === 1) ? `${days} Day, ` : `${days} Days, `;
if (hours > 0) {
difference += (hours === 0 || hours === 1) ? `${hours} Hour, ` : `${hours} Hours, `;
difference += (minutes === 0 || hours === 1) ? `${minutes} Minutes` : `${minutes} Minutes`;
return difference;
timeDiffCalc(new Date(Now), new Date(Last_Update))
thank you for the help!. I have already found the way to solve this. i just create a function and call it in the msg.payload
