I2C-bus install fail - RPI Zero W
I have a RPI Zero W with Node-RED.
I am trying to install i2c-oled and it failed. I then tried other nodes and any node that use i2c-bus fail to install.
I have confirmed that the hardware works by using i2cdetect -y 1, even went so far as to install a software i2c on bus 3 and confirmed that it also work.
pi@NanoView:~ $ i2cdetect -y 3
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
But i am unable to install any node that use i2c-bus, not sure where to start looking.
Please point me in the right direction.
Here is the error log:
2021-05-16T09:28:01.015Z Install : node-red-contrib-oled 0.2.1
2021-05-16T09:28:01.438Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-oled@0.2.1
2021-05-16T09:28:33.077Z [out]
2021-05-16T09:28:33.077Z [out] > i2c-bus@5.2.2 install /home/pi/.node-red/node_modules/i2c-bus
2021-05-16T09:28:33.077Z [out] > node-gyp rebuild
2021-05-16T09:28:42.638Z [out] make: Entering directory '/home/pi/.node-red/node_modules/i2c-bus/build'
2021-05-16T09:28:42.654Z [out] CXX(target) Release/obj.target/i2c/src/i2c.o
2021-05-16T09:28:42.707Z [err] make: *** [i2c.target.mk:113: Release/obj.target/i2c/src/i2c.o] Segmentation fault
2021-05-16T09:28:42.721Z [out] make: Leaving directory '/home/pi/.node-red/node_modules/i2c-bus/build'
2021-05-16T09:28:42.727Z [err] gyp
2021-05-16T09:28:42.733Z [err]
2021-05-16T09:28:42.735Z [err] ERR!
2021-05-16T09:28:42.740Z [err] build error
2021-05-16T09:28:42.746Z [err] gyp
2021-05-16T09:28:42.749Z [err]
2021-05-16T09:28:42.751Z [err] ERR!
2021-05-16T09:28:42.756Z [err] stack Error: make failed with exit code: 2
2021-05-16T09:28:42.756Z [err] gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
2021-05-16T09:28:42.771Z [err] gyp ERR! stack at ChildProcess.emit (events.js:314:20)
2021-05-16T09:28:42.771Z [err] gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
2021-05-16T09:28:42.771Z [err] gyp ERR! System Linux 5.10.17+
2021-05-16T09:28:42.771Z [err] gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2021-05-16T09:28:42.771Z [err] gyp ERR! cwd /home/pi/.node-red/node_modules/i2c-bus
2021-05-16T09:28:42.774Z [err] gyp
2021-05-16T09:28:42.775Z [err]
2021-05-16T09:28:42.780Z [err] ERR! node -v v12.22.1
2021-05-16T09:28:42.780Z [err] gyp ERR! node-gyp -v v5.1.0
2021-05-16T09:28:42.780Z [err] gyp ERR! not ok
2021-05-16T09:28:42.782Z [err]
2021-05-16T09:28:45.008Z [err] npm
2021-05-16T09:28:45.010Z [err]
2021-05-16T09:28:45.012Z [err] ERR!
2021-05-16T09:28:45.020Z [err] code ELIFECYCLE
2021-05-16T09:28:45.020Z [err] npm ERR! errno 1
2021-05-16T09:28:45.133Z [err] npm
2021-05-16T09:28:45.135Z [err]
2021-05-16T09:28:45.140Z [err] ERR! i2c-bus@5.2.2 install: node-gyp rebuild
2021-05-16T09:28:45.140Z [err] npm ERR! Exit status 1
2021-05-16T09:28:45.142Z [err]
2021-05-16T09:28:45.143Z [err] npm
2021-05-16T09:28:45.150Z [err] ERR! Failed at the i2c-bus@5.2.2 install script.
2021-05-16T09:28:45.150Z [err] npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
2021-05-16T09:28:45.208Z [err]
2021-05-16T09:28:45.210Z [err] npm
2021-05-16T09:28:45.212Z [err]
2021-05-16T09:28:45.219Z [err] ERR! A complete log of this run can be found in:
2021-05-16T09:28:45.219Z [err] npm ERR! /home/pi/.npm/_logs/2021-05-16T09_28_45_172Z-debug.log
2021-05-16T09:28:45.266Z rc=1
Something is horribly wrong, you appear to have managed to get a segmentation fault running make.
Can you stop node-red then run it again in a terminal and copy/paste the startup log here please, that will give us some information on your system.
Does the system run reliably apart from this issue?
yes - i can only guess it ran out of memory while trying to do that. As @colin suggests try running the install manually from the ~/.node-red directory - and paste the result here (if it fails again).
Hi dceejay
Here is the error from the terminal with NR not running.
pi@NanoView:~/.node-red $ npm install node-red-contrib-oled
node-gyp rebuild
gyp ERR! build error
gyp ERR! stack Error: make failed with exit code: 2
gyp ERR! node -v v12.22.1
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! i2c-bus@5.2.2 install: node-gyp rebuild
npm ERR!
npm ERR! Failed at the i2c-bus@5.2.2 install script.
npm ERR! /home/pi/.npm/_logs/2021-05-16T10_30_24_082Z-debug.log
Hi Colin
As far as i know, it is working fine, i am trying to add i2c to a flow, and this is where i am getting stuck.
Here is the NR Start log
pi@NanoView:~ $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.2.50:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
16 May 12:39:52 - [info]
Welcome to Node-RED
16 May 12:39:52 - [info] Node-RED version: v1.3.4
16 May 12:39:52 - [info] Node.js version: v12.22.1
16 May 12:39:52 - [info] Linux 5.10.17+ arm LE
16 May 12:39:56 - [info] Loading palette nodes
redPlc rpi_mcp23017 driver V1.0.6 (c) Ocean iiot2k@gmail.com
16 May 12:40:07 - [info] Dashboard version 2.29.0 started at /ui
16 May 12:40:08 - [info] Settings file : /home/pi/.node-red/settings.js
16 May 12:40:08 - [info] Context store : 'default' [module=memory]
16 May 12:40:08 - [info] User directory : /home/pi/.node-red
16 May 12:40:08 - [warn] Projects disabled : editorTheme.projects.enabled=false
16 May 12:40:08 - [info] Flows file : /home/pi/.node-red/flows_NanoView.json
16 May 12:40:08 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
16 May 12:40:09 - [info] Starting flows
16 May 12:40:11 - [error] [mcp23017:@20] error on init
16 May 12:40:12 - [info] Started flows
16 May 12:40:12 - [error] [function:6062eda8.0c2414] TypeError: Cannot read property 'txt' of undefined
16 May 12:40:12 - [info] [mqtt-broker:8bf8026a.48702] Connected to broker: mqtt://localhost:1883
16 May 12:40:12 - [info] [function:6062eda8.0c2414] Status is =undefined
Very odd. Which version of raspbian are you running (use cat /etc/os-release)
Have you recently updated all the raspbian packages to make sure you are up to date?
sudo apt update && sudo apt full-upgrade
That updates all the packages to the latest available for the version of raspbian you are using, but does not update raspbian itself.
Hi Colin
pi@NanoView:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="RaspbianForums - Raspbian"
BUG_REPORT_URL="RaspbianBugs - Raspbian"
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Well I have no idea I am afraid. It installs fine on a Zero here, using nodejs 14 but I wouldn't expect it to be be the nodejs version that matters.
I suppose your make might be corrupted, you could try reinstalling that, I think it is installed by build-essential.
sudo apt remove build-essential
Make sure it has removed it by running which make which should not show anything, then
sudo apt install build-essential
Hi Colin / dceejay
I decided to start "Fresh"...
Install RPI lite, setup I2c, update and upgrade, install NR.
And now it works???
Not sure why, as it is the same i did before, hate it when i don't know why it works now and not before.
Thank you for your time and assistance.
Having had the problems you had before I think I would, if possible, have used a new good quality SD card and either ditched the original, or at least marked it as suspect.
