I is there some thing that I am missing? I am having a bugger of a time getting i2cdetect -y 1 to find anything on raspberry pi 4s or 400s
Dave
Dave
Hi.
Make sure you have enabled the I2C option in the raspi-config menu.
It it isn't enabled there, you are not going to get anywhere I feel.
Sorry if you have done it, but it is better to state the bleeding obvious than not.
I did do that several times. You are correct to master the obvious first. The pi 400 magically started up last night (i2c) I It took several reboots.
Dave
I'd suspect a loose connection somewhere could be causing your issue
Like @cymplecy said or have you forgotten the pull - up resistor?
The Pi has built in pull-ups on the i2c pins
Yep, should have remembered that!
The Rpi 400 detected the i2c BUS as soon as I did full upgrade and then upgraded to --node16 Node-RED. Don't ask me why. I am just happy to be back online. I am going to hold off on Bullseye and "OS Legacy" as long as my current Buster revs are doing what I need on my hardware. Too many fish to fry at the moment.
Dave
Good to hear all is now good.
I have several PiZero running Jessie and very old NR versions
They do the job I need them to and I leave them alone
