Icon size and apperance
i am trying to do my first steps with dashboard 2.0.
I need different icons shown with different inputs.
All i could find are icons with switches or buttons.
Next thing is to change the size of the icons.
Thx in advance
Olmuk
What dashboard widgets do you want to use icons with?
Do you need the icon size to change dynamically or do you just want to change the default size?
You will probably have to think about jbudds' question but here is a simple example of an icon. If you change iconLarge to iconSmall the size and position of the icon will change. (the icon is just displayed in the Group backdrop)
<template>
    <div class="iconLarge">
        <span class="mdi mdi-weather-sunny"></span>
    </div>
</template>
<script>
    export default {
        data() {
            // define variables available component-wide
            // (in <template> and component functions)
            return {
        watch: {
            // watch for any changes of "count"
        computed: {
            // automatically compute this variable
            // whenever VueJS deems appropriate
        methods: {
            // expose a method to our <template> and Vue Application
        mounted() {
            // code here when the component is first loaded
        unmounted() {
            // code here when the component is removed from the Dashboard
            // i.e. when the user navigates away from the page
</script>
<style>
    /* define any styles here - supports raw CSS */
    .iconLarge {
        font-size: 100px;
        justify-content: right;
        align-items: center;
        text-align: center;
	.iconSmall {
		font-size: 45px;
</style>
Thanks for your answers.
That is my problem because i don‘t really know where to put im the code.
I guess the template ?
Is it possible to show me that with the flows ?
Nowadays in Dashboard 2 im using VUE features, you can use their website even for live-testing of your code in their Vue-Playground. It helped me a lot to learn the capabilites of Node-red ui-Templates.
you will not need a flow to test the in Node-Red.... just an UI-Template and copy-paste the code.... there are good examples/demos in the Node-Red-Tutorials
