I have put
<script src="https://code.iconify.design/1/1.0.7/iconify.min.js"></script>
into head section, but I cannot figure out what to put in the button setup for the icon field to use this -
<span class="iconify" data-icon="simple-icons:sky"></span>
Any ideas please ?
Syntax for button's Icon field:
For example the home icon from "dashicons" admin home • Dashicons • Iconify
Also the iconify is now some version steps up.
<script src="https://code.iconify.design/2/2.0.3/iconify.min.js"></script>
Thanks I have update head section and used iconify-simple-icons:sky
and this now works. Is there an easy way to change size please ?
There is easiest way in the world
iconify-dashicons:admin-home 48px
Thanks,
Sorry if I’m asking dumb questions but I couldn’t find relevant NR information on this subject.
At least this post will help others like me
It is not dumb question. As the dashboard is just a bunch of nodes but 1 person as maintainer it is not possible to have every corner covered in help files. But luckily there is common place for every node - the github page, where Readme covers most of basics.
Known that such idea can't be figured out by regular user but that's where the community works out best.
Hi, I spoke too soon.
Using the new iconify script is ok if used as an icon button node, but no longer works in text node label.
I note the format is different with new version, but even after updating my text nodes the icons do not display.
<span class="iconify" data-icon="fa-solid:hot-tub"></span>
The old syntax only works with the old script and not the new, so I cannot use the updated version, not sure what benefits it offers ?
<span class="iconify icon:fa-solid:hot-tub"></span>
No I dont know exactly. I haven't tried with text node. Sure if it does not work, the old script should be used. With old syntax.
