Hello. Noob question, but... )
it's posible to use if/else in JSONata expressions?
I have this expression.
"brightness_pct" : payload.brightness,
"hs_color" : [payload.hue, payload.saturation]
In rare case in msg not exist payload.hue and/or payload.saturation. And in this case I need to use just
I try to find examples, but unsuccessful
Welcome to the forum @iStitch07,
Good question. You probably know that there is the ternary conditional operator in jsonata. However the trick part of the question is:
The bottom line is that jsonata can only operate on a valid JSON string.
If payload.hue does not exist and payload,saturation equals, lets say 5, what hs_color will looks like ?
[ , 5] or [null , 5] or [undefined,5] ?
this works for me:
"hs_color" : payload.hue and payload.saturation ? [payload.hue, payload.saturation]
Update:
"hs_color" : payload.hue != null and payload.saturation != null ? [payload.hue, payload.saturation]
This is actually better as it will work if hue or saturation = 0
If at least one or both values don’t exist, I need to skip full line, include “hs_color” too
Looks great, I will try this, because I need to complete skip this line if one or both values not exist
payload.hue != null and payload.saturation != null ? "hs_color": [payload.hue, payload.saturation]
Update:
But coma in first line will be cause of error if I skip the second line
Update2: my variant got a syntax error. Your variant pass the syntax validation, but will cause error with empty “hs_color” service calling
@iStitch07 is this a purely academic question?
If not and you really need to solve this then why not just defer to a function node. The logic you require is quite simple to achieve in standard js.
No, it’s not academic question. I try to optimize this flow
If I will add additional function node, I will need to add and another service calling node. And it’s not “pretty”
Um, no? Confused!
Whatever you want to do in jasonata you can do +more in a function node.
Just return the msg with correct properties/values surely? Not sure why you would need to add 2 outputs and 2 blue nodes (whatever they are)?
I’m not sure and will try
If it possible to create valid json in function node and pass it in payload to data field in service call node - its will be answer
You don't create JSON really (JSON is a string representation of a JavaScript object)
You build a property in the msg (usually payload) then send it onwards.
E.g.
let x;
if(msg.something) {
x = msg.thisval
} else {
x = msg.thatval
msg.payload = {
brightness : x
In fact, you can probably just set a new property in the msg then set that data property to the same msg.prop you invent
E.g.
if(msg.something) {
msg.brightness = msg.thisval
} else {
msg.brightness = msg.thatval
Then change the data option to msg and enter brightness
But we return to begin.
I already do something like this in function node
var brg_name = msg.topic + '.brightness';
var sat_name = msg.topic + '.saturation';
var hue_name = msg.topic + '.hue'
var new_val = {};
if(msg.payload.Brightness >= 0) {
new_val.brightness = msg.payload.Brightness;
flow.set(brg_name, msg.payload.Brightness);
new_val.saturation = flow.get(sat_name);
new_val.hue = flow.get(hue_name);
if(msg.payload.Hue >= 0) {
new_val.brightness = flow.get(brg_name);
new_val.hue = msg.payload.Hue;
flow.set(hue_name, msg.payload.Hue);
if(msg.payload.Saturation >= 0) {
new_val.saturation = msg.payload.Saturation;
flow.set(sat_name, msg.payload.Saturation);
msg.payload = new_val;
But in service call node I need to set param for service calling
If I have only brightness in payload, then I need to call service
Else, if I have payload.hue AND payload.saturation, I need to call service with this param
Yeah so do that in a function node.
I really don't understand why you don't just do exactly what you're saying
In the function node, just do the logic & update a property in msg (any property you desire) with either
{ "brightness_pct" : msg.payload.brightness }
or
{ "brightness_pct" : payload.brightness, "hs_color" : [msg.payload.hue, msg.payload.saturation] }
Then set the data option in the blue node to msg type and the matching property name
The blue node will recieve the data you send. No need for jsonata.
An I missing something?
What node is that blue node?
the one i looked at doesnt permit JSONata in the Data field but it does permit you to send data in msg.payload.data
If the incoming message has a payload property with domain , service set it will override any config values if set.
If the incoming message has a payload.data that is an object or parseable into an object these properties will be merged with any config values set.
So if that is the same for your node then something like this might work...
//first add a data property and set brightness_pct to msg.payload.brightness
msg.payload.data = {
"brightness_pct" : msg.payload.brightness;
//next, if msg.payload.hue && payload.saturation are present, add hs_color property
if(msg.payload.hue && payload.saturation) {
msg.payload.data.hs_color = [msg.payload.hue, msg.payload.saturation];
I was try change function node with adding this block
if(new_val.brightness && (!new_val.hue || !new_val.saturation) ) {
new_val.params = '{ "brightness_pct" : ' + new_val.brightness + ' }';
} else {
new_val.params = '{ "brightness_pct" : ' + new_val.brightness + ', "hs_color" : [' + new_val.hue + ', ' + new_val.saturation + '] }';
After add to blue node in data field - {{payload.params}}
And got a error
Call-service API error. Error Message: extra keys not allowed @ data['0']
But in debug all look fine
{"brightness":100,"saturation":100,"hue":234,"params":"{ \"brightness_pct\" : 100, \"hs_color\" : [234, 100] }"}
Sorry, I’m little slow because working on iPad now
Blue node its home assistant call service node. I will try do use payload.data
node-red-contrib-home-assistant-websocket
Why are you doing JSON strings?
Did you try the function I wrote out for you?
The help says...
So try the function I stated & pass an object (not JSON)
EDIT, to allow hue 0 and saturation 0 values...
if(msg.payload.hasOwnProperty("hue") && payload.hasOwnProperty("saturation")) {
And just leave the Data field blank.
Easy, easy - its my first week with node-red
I still learning
I will try your code from last post
