If I am assigning response body in msg.payload than flow breaks
request(reqOptions, function (error, response, body) {
    node.warn(response);
    // node.warn(msg.payload);
    if(error){
        msg.publish=false;
        node.send(msg);
        node.done();
    if(response.statusCode>=200 && response.statusCode<=226){
        msg.publish=true;
        msg.payload = response;
        node.send(msg);
        node.done();
    }else{
        msg.publish=false;
        node.send(msg);
        node.done();
return
Error
11 Feb 13:00:58 - TypeError: Cannot assign to read only property 'writeQueueSize' of object '#<TCP>'
    at _clone (/home/abhishek/.nvm/versions/node/v10.15.3/lib/node_modules/node-red/node_modules/clone/clone.js:162:16)
    at _clone (/home/abhishek/.nvm/versions/node/v10.15.3/lib/node_modules/node-red/node_modules/clone/clone.js:162:18)
    at clone (/home/abhishek/.nvm/versions/node/v10.15.3/lib/node_modules/node-red/node_modules/clone/clone.js:202:10)
    at Object.cloneMessage (/home/abhishek/.nvm/versions/node/v10.15.3/lib/node_modules/node-red/node_modules/@node-red/util/lib/util.js:90:13)
    at sendResults (/home/abhishek/.nvm/versions/node/v10.15.3/lib/node_modules/node-red/node_modules/@node-red/nodes/core/function/10-function.js:39:55)
    at Object.send (/home/abhishek/.nvm/versions/node/v10.15.3/lib/node_modules/node-red/node_modules/@node-red/nodes/core/function/10-function.js:122:21)
    at Object.send (Function node:58825e1f.73d0c [Create an entry]:1:313)
    at Request._callback (Function node:58825e1f.73d0c [Create an entry]:37:14)
    at Request.self.callback (/home/abhishek/.node-red/node_modules/request/request.js:185:22)
    at Request.emit (events.js:189:13)
    at Request.<anonymous> (/home/abhishek/.node-red/node_modules/request/request.js:1161:10)
    at IncomingMessage.<anonymous> (/home/abhishek/.node-red/node_modules/request/request.js:1083:12)
    at Object.onceWrapper (events.js:277:13)
    at IncomingMessage.emit (events.js:194:15)
    at endReadableNT (_stream_readable.js:1125:12)
    at process._tickCallback (internal/process/next_tick.js:63:19)
I am using a request module inside function node
The response object is not a cloneable object. Pick out the properties you want from it and assign just those, not the whole object.
Alternatively, use the HTTP Request node so you don't have to write all this code yourself.
