What I am trying to do:
Enable access to the node-red editor hosted on a VM through the web using IIS as a reverse proxy.
The node-red editor is accessible through the reverse proxy, but displays "Lost connection to server, reconnecting in ..." and throws WebSocket handshake errors (reverse proxy returns 502.3).
if connected to the VM directly, the node-red editor works as expected
Without any luck I have been trying to figure out how to correctly configure my reverse proxy. Hopefully someone here can help me out ![]()
The setup I am using:
NodeRed: Ubuntu 18.04 w/ node-red
ReverseProxy: Windows Server 2016 w/ IIS 10.0, ARR 3.0
IIS / ARR Config (parts of):
rewrite
globalRules
rule name="Force HTTPS" enabled="true" stopProcessing="true"
match url="(.*)"
conditions
add input="{HTTPS}" pattern="^OFF$"
conditions
action type="Redirect" url="https:{HTTP_HOST}{R:1}"
rule
globalRules
rewrite
proxy
enabled="true"
httpVersion="PassThrough"
keepAlive="false"
timeout="00:06:00"
reverseRewriteHostInResponseHeaders="true"
xForwardedByHeader=""
includePortInXForwardedFor="false"
proxy
Site / URL Rewrite config:
?xml version="1.0" encoding="UTF-8"?
configuration
system.webServer
rewrite
outboundRules
rule name="NodeRed_Outbound" preCondition="ResponseIsHtml1" enabled="true"
match filterByTags="A, Area, Base, Form, Frame, Head, IFrame, Img, Input, Link, Script" pattern="^http(s)?://{VM domain removed}:1880/(.*)"
action type="Rewrite" value="http{R:1}://{IIS}/{R:2}"
rule
preConditions
preCondition name="ResponseIsHtml1"
add input="{RESPONSE_CONTENT_TYPE}" pattern="^text/html"
preCondition
preConditions
outboundRules
rules
rule name="NodeRed_Inbound" enabled="true" stopProcessing="true"
match url="(.*)"
action type="Rewrite" url="http://{VM domain removed}:1880/{R:1}"
conditions
add input="{HTTP_HOST}" pattern=".*{IIS subdomain removed}\.{IIS domain removed}\.{IIS toplevel domain removed}"
add input="{CACHE_URL}" pattern="^(.+)://"
conditions
serverVariables
serverVariables
rule
rules
rewrite
staticContent
clientCache cacheControlMode="NoControl"
staticContent
httpProtocol allowKeepAlive="false"
customHeaders
add name="Strict-Transport-Security" value="max-age=63072000; includeSubdomains"
add name="X-Content-Type-Options" value="nosniff"
add name="Referrer-Policy" value="no-referrer"
add name="X-XSS-Protection" value="1; mode=block"
add name="X-Robots-Tag" value="none"
add name="X-Download-Options" value="noopen"
add name="X-Permitted-Cross-Domain-Policies" value="none"
customHeaders
httpProtocol
security
requestFiltering allowDoubleEscaping="true"
requestLimits maxAllowedContentLength="2000000000"
requestFiltering
security
system.webServer
configuration
Some details and logs:
Node-red editor shows:
Browser console log shows:
WebSocket connection to 'wss://{removed domain}/comms' failed: Error during WebSocket handshake: net::ERR_CONNECTION_RESET
node-red audit log:
0|node-red | 12 Dec 20:02:07 - [audit] {"event":"comms.open","level":98,"timestamp":1544641327139}
freb log:
Summary
Url https://(domain removed):443/comms
App Pool {removed}
Authentication anonymous
User from token NT-AUTORITÄT\IUSR
Activity ID {8000006E-0003-D200-B63F-84710C7967BB}
Site xx
Process 11744
Failure Reason STATUS_CODE
Trigger Status 101
Final Status 502.3
Details
GENERAL_REQUEST_HEADERS:
Headers="
Cache-Control: no-cache
Connection: Upgrade
Pragma: no-cache
Upgrade: websocket
Accept-Encoding: gzip, deflate, br
Accept-Language: en-US,en;q=0.9
Cookie: _ga=GA1.2.978382240.1544564967; _gid=GA1.2.1401031310.1544564967
Host: {domain removed}
User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.110 Safari/537.36
Origin: https://{domain removed}
Sec-WebSocket-Version: 13
Sec-WebSocket-Key: /Ae4mACNf3sBlkYJZftrHA==
Sec-WebSocket-Extensions: permessage-deflate;
client_max_window_bits "
GENERAL_RESPONSE_HEADERS:
Headers="
Upgrade: websocket
Sec-WebSocket-Accept: oEMCEPAq+xLfe6s9i4xTr9PyZoY=
X-Powered-By: ARR/3.0
Connection: Upgrade
X-Powered-By: ASP.NET
Strict-Transport-Security: max-age=63072000;includeSubdomains
X-Content-Type-Options: nosniff
Referrer-Policy: no-referrer
X-XSS-Protection: 1;mode=block
X-Robots-Tag: none
X-Download-Options: noopen
X-Permitted-Cross-Domain-Policies: none"
GENERAL_FLUSH_RESPONSE_END:
BytesSent="0", ErrorCode="The parameter is incorrect. (0x80070057)"
MODULE_SET_RESPONSE_ERROR_STATUS:
ModuleName ApplicationRequestRouting
Notification EXECUTE_REQUEST_HANDLER
HttpStatus 502
HttpReason Bad Gateway
HttpSubStatus 3
ErrorCode The parameter is incorrect.
(0x80070057)
ConfigExceptionInfo
SET_RESPONSE_ERROR_DESCRIPTION:
ErrorDescription There was a connection error while trying to route the request.
