Summary of Issues: NR Proxy Routing in the Apache2 - conf files for Virtual Host, WSS connection errors, Cannot Click Inject Nodes, Dashboard "Not Loading"
Scenario:
I am consolidating multiple websites I host onto one server and successfully setup majority of my static sites to the one one cloud server. I have a NR instance running alongside with them attached to it's own Apache2 routed ServerAlias
Problem: The NR instance is giving issues after I manage the Apache2 conf settings for the Virtual Host associated with NR.
My case scenario with NR is that I have ( pardon if overly detailed)
~/www/server1.com
~/www/server2.com
~/www/nr-server3.com
and those are symlinked to the Apache html folders:
/var/www/server1.com
/var/www/server2.com
/var/www/nr-server3.com <---- (This is not populated with anything,
NR will be serving via http node endpoints)
Node-Red Settings worth noting:
httpAdminRoot: '/admin',
httpStatic: '/home/ubuntu/www/nr-server3.com/public_html',
Apache Configuration:
(Running on Ubuntu)
Using Certbot as the CA I have a file:
/etc/apache2/sites-available/nr-server3.com-le-ssl.conf
Inside the File: (anonymized)
<VirtualHost *:443>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request's Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
#ServerName www.example.com
SSLProxyEngine On
ProxyPreserveHost On
ProxyRequests Off
ProxyPass /admin/comms wss://localhost:1880/admin/comms
ProxyPassReverse /admin/comms wss://localhost:1880/admin/comms
ProxyPass / https://localhost:1880/ connectiontimeout=5 timeout=30
ProxyPassReverse / https://localhost:1880/
ServerAdmin webmaster@nr-server1.com
ServerName nr-server1.com
ServerAlias nr-server1.com
DocumentRoot /var/www/nr-server1.com/public_html
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
SSLCertificateFile /etc/letsencrypt/live/nr-server3.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/nr-server3.com/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost>
</IfModule>
Further:
I've had issue with what I listed above and it started out with the WSS connection issues. I seem to have the /admin/comms/ part correct in the Apache settings, because now it doesn't complain about wss disconnection.
But I cannot get the Inject node to work in the IDE, and Dashboard /ui is console complaining that it cannot load: GET https://nr-server3.com/ui/loading.html 404 (Not Found) , Which displays some elements, but the buttons are not working.
At this point I'm thinking some setting in the Apache2 /etc/apache2/sites-available/nr-server3.com-le-ssl.conf are not working, in relation to routing the wss essentials / endpoints / or whatever it needs.
and possibly my NR settings.js might need some adjustment as well... ?
I appreciate any assistance in clarifying this process of essentially turning NR into a fully working "Virtual Host" behind Apache2, with wss, and my case scenario where I am serving NR httpStatic content in a different folder.
