Node-RED, Apache,Proxypass - no debug data
Hey All,
Issue: debug node dosn't work - no debug data
I have got an issue after securing Node-RED by Apache web server with ProxyPass and uiHost:127.0.0.1,
adminAuth.
  1. What I have:
[Issue]
When I run Node-RED in browser locally: localhost:1880 then evrything works.
Into flows, debug nodes works (debug data are retrived in debug panel), mqtt and mysql shows that they are connected.
But when I run Node-RED in browser on WAN site e.g https://io.company.com/
I could login to Node-RED, I see running flows - database accepts data from mqtt.
The problem is - debug node dosn't work (nothing shows in debug panel), mqtt node dosn't show that there is connected,also mysql node dosn't show that there is connected.
Did I omit something in the configuration?
Best regards.
Bronto
the websocket connection back to the editor (debug) also needs to be allowed through your proxy.
@dceejay - I thank You
I have done some research on the web, and found out some informations about RewriteCon for websocket. I have implemented that solution and now, my Node-RED debug node works in proxy.
Best regards
Bronto
@bronto any chance you could post a sanatized version of your Apache config? It would be useful as a reference.
OK - I could, no problem.
  1. There's a popout on that forum which tells us about security of Node-red.
Shortly - OS Ubuntu, Node-Red runs by tux user.
Tux home directory: /home/tux/.node-red/settings.js.
Three important parameters
uiPort:process.env.PORT || 3005,
uiHost:"127.0.0.1",
httpAdminRoot:'/nodered',
And now
  1. Apache virtual host setup (SSL by letsencrypt)
ServerName example.com ServerAdmin you@example.com DocumentRoot /var/www/html/example.com
RewriteEngine On
RewriteCond %{HTTP:Upgrade}   =websocket    [NC]
    RewriteRule /nodered(.*)              ws://localhost:3005/nodered$1 [P,L]
ProxyPreserveHost On
ProxyRequests Off
ProxyVia Off
<Proxy *>
    Order deny,allow
    Require all granted
</Proxy>
ProxyPass 		/nodered		http://localhost:3005/nodered
ProxyPassReverse	/nodered		http://localhost:3005/nodered
ErrorLog ${APACHE_LOG_DIR}/error-example.com.log
CustomLog ${APACHE_LOG_DIR}/access-example.com.log combined
SSLCertificateFile       /etc/letsencrypt/live/example.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/example.com/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
Above configuration works for me.
Best regards
Bronto
Awesome, thanks @bronto !
I currently have my http end points all proxied via Apache, but it would be nice to proxy the admin interface as well!
I am having trouble dealing with the websocket connection with two Node Red instances: one local and another one on different Raspberry Pi in same private network. I had my local device (the one with Apache running) setup working by following this and this discussion. Here is my Apache Virtual Host configuration for all 443 traffic:
<IfModule mod_ssl.c>
<VirtualHost *:443>
RewriteEngine On
RewriteRule /node1(.*)     ws://localhost:1234/node1$1 [P,L]
ProxyRequests Off
ProxyVia Off
<Proxy *>
    Order deny,allow
    Require all granted
</Proxy>
# This is the first (local) node-red instance, works well with the Rewrite lines above
ProxyPass /node1 http://localhost:1234/node1
ProxyPassReverse /node1 http://localhost:1234/node1
# This is the second node-red instance running on another Pi, ProxyPass works but websockets do not
ProxyPass /node2 http://192.168.x.x:1234/node2
ProxyPassReverse /node2 http://192.168.x.x:1234/node2
ServerName mydomain.com
SSLCertificateFile /etc/letsencrypt/live/mydomain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mydomain.com/privkey.pem
</VirtualHost>
</IfModule>
I have learned that I could separate the websockets by custom paths like this:
Node server:
var io = require('socket.io')({ path: '/ws_website1'}).listen(server);
Client HTML:
<script src="/ws_website1/socket.io.js"></script>
<script>
var socket = io('', { path: '/ws_website1' });
I am guessing that I should edit my node modules to make this happen, but I have no idea which one to look at. Any help would be greatly appreciated.
Thank you!
Hjellmarr
Hy all,
I am running node-red with https enabled (see http://www.steves-internet-guide.com/securing-node-red-ssl/) and wanted to proxie it from another account. Let say, NR is running at my.server1:1880.
There is a second server exposed via DNS at my.server2, and I wanted to use this adress for node-red (without :1880). This server is running Debian10 and a clean installation of Apache 2, ssl certificates from Letsencrypt.
Finally I managed to get node-red running without any rewrites.
I set /root/etc/apache2/sites-available/000-default-le-ssl.conf:
<VirtualHost *:443>
	ServerAdmin webmaster@localhost
	ErrorLog ${APACHE_LOG_DIR}/error.log
	CustomLog ${APACHE_LOG_DIR}/access.log combined
	ServerName my.server2
	SSLProxyEngine on
    #ProxyPreserveHost On
    ProxyRequests Off
	ProxyPass /comms wss://my.server1:1880/comms
	ProxyPassReverse /comms wss://my.server1:1880/comms
	ProxyPass / https://my.server1:1880/
    ProxyPassReverse / https://my.server1:1880/
	SSLEngine on
	SSLCertificateFile /etc/letsencrypt/live/my.server2/fullchain.pem
	SSLCertificateKeyFile /etc/letsencrypt/live/my.server2/privkey.pem
</VirtualHost>
</IfModule>
Hope this can help someone to get things running. wss://my.server1:1880/comms seems to be necessary to get websockets running.
Thank you, this works great! Took me a while to figure it out because not all the required apache modules were loaded. I had to run enable proxy, proxy_http, and proxy_wstunnel. Sharing in case others have the same issue.
sudo a2enmod proxy
sudo a2enmod proxy_http
sudo a2enmod proxy_wstunnel
Strange enough, i recently had to change my setup to add a second node red server to the setup. You can use
ProxyPass /nodered1/
to use a different path, But for whatever reason, websockets are working only on one of the servers, while the second dores not have any debug messages in node red.
I assume there is some misconfiguration somehow, but it seems this kind of trouble is not uncommon for Apache. Found a similar case on the net. After changing to ngix things seemed to work better...
Yes, NGNX is a much better web server. Typically uses a lot less resources than Apache as well. Caddy is also quite good.
When using nginx, I always add some conf settings like this, to enable websockets:
        location / {
            proxy_pass http://localhost:1880/;
            proxy_http_version 1.1;
            proxy_set_header Upgrade $http_upgrade;
            proxy_set_header Connection "upgrade";
            proxy_set_header X-Real-IP $remote_addr;
