I'm missing the Class field in my dashboard nodes
What I have:
What I want:
notice the Class field is missing.
also, the dark/custom theme doesn't work for me (might be unrelated but just mentioning it)
other than the 'CSS' part, the node-red installation is working fine, I tried a serial reader, to integrate it with an arduino.
I'm new, this might be a dumb fix
Installation of the themes
Install via the Palette Manager
Search for @node-red-contrib-themes/theme-collection
Install with npm
Run the following command from within the Node-RED user data directory (by default, $HOME/.node-red).
npm install @node-red-contrib-themes/theme-collection
Click the pencil on the right side of input field
I added a new tab and group, there still isn't a CSS field.
The theme works now, though. Thanks!
What version of Node-red do you have?
I think the Class field was introduced for v3.0
Please paste images directly into the forum posts.
I should have the latest version, I just downloaded it.
I checked, it's v3.1.9
node-js v22.1.0
Sorry, I'll take care next time!
Would be good if you could edit the post and paste your screenshots in directly :angel:
We need the dashboard version - look in the palette manager (where you install dashboard nodes)
hi, the dashboard version is v1.0.2. I'm using dashboard-evi.
Then that is why you dont have "class" option.
TBH, not many people use that (most use node-red-dashboard and many are now using the successor @flofuse/node-red-dashboard AKA dashboard 2)
Ahh got it. I can now see the class thingy.
Thanks for your help!
also, what's the dashboard 2? How is it better, and is it easier to use, being a beginner?
Better in that it uses modern tooling and is being actively developed. It is based on Vue and vuetify.
Dashboard 1 is more mature but uses the now unsupported angularjs and is not being actively developed.
If you are beginner, it may be worth not learning the ins & outs of dashboard 1 and skip straight to dashboard 2
Dashboard 1 could very well be abandoned if any CVEs arise in the old unsupported underlying angularjs.
Alright, I'm now trying using the flofuse version. Thanks for your help!
