Image works on Docker but not on Kubernetes
I have a simple Dockerfile:
FROM nodered/node-red
# Copy package.json to the WORKDIR so npm builds all
COPY package.json .
COPY node-red-static .
COPY defaults .
RUN npm install --unsafe-perm --no-update-notifier --no-fund --only=production
# NodeRED configuration
COPY .node-red/settings.js /usr/src/node-red/.node-red/settings.js
COPY .node-red/flows.json /data/flows.json
That I turned into an image and run it using:
docker run -it --rm -p 1880:1880/tcp ghcr.io/myorg/myImage:latest
Works like a charm. Now I tried to deploy that to a MicroK8S Kubernetes instance using a deployment
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: core
spec:
  replicas: 2
  selector:
    matchLabels:
      app: core
  template:
    metadata:
      labels:
        app: core
    spec:
      containers:
      - name: core
        image: ghcr.io/myorg/myImage:latest
        ports:
        - containerPort: 1880
        imagePullPolicy: Always
        volumeMounts:
          - name:  facility-volume
            mountPath:  '/opt/facility/facility.json'
            subPath: facility.json
          - name: core-export
            mountPath: "/export"
        resources:
          limits:
            memory: "8Mi"
            cpu: "500m"
        envFrom:
        - secretRef:
      imagePullSecrets:
      - name: regcred
      volumes:
          configMap:
        - name: core-export
          persistentVolumeClaim:
            claimName: export-pv-claim
K8S indicates a successful deployment, but port 1880 is silent.
So I checked the log of the pod. It contains exactly 2 lines:
core@0.1.0 start /usr/src/node-red
node-red --settings ./.node-red/settings.js --userDir ./.node-red "--userDir" "/data"
Then I checked ps -A and get
PID   USER     TIME  COMMAND
    1 node-red  0:09 npm
   16 node-red  2:08 node /usr/src/node-red/node_modules/.bin/node-red --settin
   30 node-red  0:00 /bin/sh
   35 node-red  0:00 ps -A
Which would indicate, the application is running? (Or stuck?)
What do I miss?
Update: I tried the same with a naked image:
kind: Deployment
metadata:
  labels:
    app: red-playground
spec:
  replicas: 2
  selector:
    matchLabels:
      app: red-playground
  template:
    metadata:
      labels:
        app: red-playground
    spec:
      containers:
      - name: red-playground
        image: nodered/node-red:latest
        ports:
        resources:
          limits:
            memory: "8Mi"
            cpu: "500m"
      imagePullSecrets:
      - name: regcred
apiVersion: v1
kind: Service
metadata:
  labels:
    app: red-playground
spec:
  type: ClusterIP
  ports:
  - name: http
    port: 1880
    protocol: TCP
    targetPort: 1880
  selector:
    app: red-playground
  sessionAffinity: ClientIP
There the log says:
> node-red-docker@1.3.4 start /usr/src/node-red
> node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"
5 May 04:21:33 - [info]
Welcome to Node-RED
5 May 04:21:35 - [info] Node-RED version: v1.3.4
5 May 04:21:35 - [info] Node.js  version: v10.24.1
5 May 04:21:35 - [info] Linux 5.8.0-50-generic x64 LE
But no luck on port 1880. I must be missing something?
Looks like you might need to use a NodePort instead of a ClusterIP in your service to expose the two node-red replicas outside your cluster (assuming these replicas are on a single node)
@NotQuiteAllThere : got an example YAML I can learn from?
# node-red deployment
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: node-red
spec:
  replicas: 1
  selector:
    matchLabels:
      app: node-red
  template:
    metadata:
      labels:
        app: node-red
    spec:
      containers:
      - name: node-red
        ports:
# node-red service
apiVersion: v1
kind: Service
metadata:
  labels:
    app: node-red
spec:
  type: NodePort
  selector:
    app: node-red
  ports:
    - protocol: TCP
      port: 1880
      targetPort: 1880
      nodePort: 30330
With the above you'll need access to the latest Node Red image. For minikube:
minikube cache add nodered/node-red:latest
And to access the service, you'll need to get hold of the cluster's ip address. For minikube:
minikube ip
Then to access the cluster use the returned IP address and the port defined in the service (30330 in the service above).
http://<ip-address-of-cluster>:30330
Be careful though, kubernetes applications are meant to be stateless so you might lose Node Red data if you don't use persistent volumes for the /data volume. However the above should be a good starting point or useful as a proof-of-concept.
