Img can't display in Node-red running in docker
Hi all, I have setup node-red in docker on ubuntu 16.04.6.
I have changed the settings.js (home/gaofei/.node-red) to
httpStatic: '/home/gaofei/img',
and I add a ui_template and config it as
<div class="c1">
<img src="/3.jpg" height="400" width="400" ><br/>
</div>
But the img can not be displayed successfully.
docker logs mynodered
> node-red-docker@1.0.6 start /usr/src/node-red
> node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"
17 May 08:35:18 - [info]
Welcome to Node-RED
17 May 08:35:18 - [info] Node-RED version: v1.0.6
17 May 08:35:18 - [info] Node.js  version: v10.20.1
17 May 08:35:18 - [info] Linux 4.4.0-151-generic x64 LE
17 May 08:35:18 - [info] Loading palette nodes
17 May 08:35:19 - [info] Dashboard version 2.22.1 started at /ui
17 May 08:35:19 - [info] Settings file  : /data/settings.js
17 May 08:35:19 - [info] HTTP Static    : /home/gaofei/img
17 May 08:35:19 - [info] Context store  : 'default' [module=memory]
17 May 08:35:19 - [info] User directory : /data
17 May 08:35:19 - [warn] Projects disabled : editorTheme.projects.enabled=false
17 May 08:35:19 - [info] Flows file     : /data/flows.json
17 May 08:35:19 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
17 May 08:35:19 - [info] Starting flows
17 May 08:35:19 - [info] Started flows
17 May 08:36:16 - [info] Stopping flows
17 May 08:36:16 - [info] Stopped flows
17 May 08:36:16 - [info] Starting flows
17 May 08:36:16 - [info] Started flows
17 May 08:36:25 - [error] [file in:read mp3] Error: ENOENT: no such file or directory, open '/img/1.mp3'
If just running node-red in WIN10 or Ubuntu , not installed in docker ,the img can show successfully.
I have tried to change the ui path in settings.js and it works,so it proves that the settings.js file I modified is the correct one.
Could you please give some advise ?
Thanks .
Hi. I'm am by no means a docker expert but I'm fairly certain you can't simply access directories on the host.
Perhaps this would help?
Thanks for your reply. I use the command:
docker run -it -p 1880:1880 -v /home/gaofei/.node-red:/data --name mynodered nodered/node-red
So the host /home/gaofei/.node-red directory is bound to the container /data directory.
I also tried to copy img to /data/ directory or /home/gaofei/.node-red , still no effect.
Solved .
httpStatic: '/data/img',
