i added a image in template node
but image is not showing.i write this code on template editor.
Do you mean an image ,bmp .jpg .or a web page .html ?
image in jpg format
In settings.js there is a setting for httpStatic, you need to set this path to a location where you want to serve your images from. Then restart NR.
eg create a folder in your NR directory called images and set the path to './images' then use
<img src="filename">
No, not correct, you have two paths defined, you should only have one (what I know)
Besides that, I use also a slash in front of my image names
Like
img src="/captured31.jpg"
When i make changes on httpstatic and define path node-red not able to start.when i launch from cmd it generate error.
Backslashes need to be escaped with another backslash. E.g. c:\\users\\xxx\\...
Better yet, use regular slashes. E.g. c:/users/xxx/...
Lastly, remove the nol/ example.
Also, in your screenshot, you have 2 httpStatic: entries. This is not valid. There should be only one.
You run under Windows....I do not
Access rights to folder for images?
Start Node-Red from command prompt:
node-red-start
study what is printed, copy & paste here so we can help debugging
Microsoft Windows [Version 10.0.19045.2846]
(c) Microsoft Corporation. All rights reserved.
C:\Users\Admin>node-red
4 May 01:04:58 - [info]
Welcome to Node-RED
4 May 01:04:58 - [info] Node-RED version: v3.0.2
4 May 01:04:58 - [info] Node.js version: v18.16.0
4 May 01:04:58 - [info] Windows_NT 10.0.19045 x64 LE
4 May 01:05:00 - [info] Loading palette nodes
4 May 01:05:15 - [info] Worldmap version 2.37.2
4 May 01:05:15 - [info] Dashboard version 3.4.0 started at /ui
cpu backend was already registered. Reusing existing backend factory.
Platform node has already been set. Overwriting the platform with [object Object].
4 May 01:05:16 - [warn] ------------------------------------------------------
4 May 01:05:16 - [warn] [@binsoul/node-red-contrib-string-extract/binsoul-string-extract] Error: Cannot find module 'jsonata'
Require stack:
- C:\Users\Admin.node-red\node_modules@binsoul\node-red-contrib-string-extract\dist\string-extract\Action\ExtractAction.js
- C:\Users\Admin.node-red\node_modules@binsoul\node-red-contrib-string-extract\dist\string-extract\ActionFactory.js
- C:\Users\Admin.node-red\node_modules@binsoul\node-red-contrib-string-extract\dist\string-extract\Node.js
- C:\Users\Admin\AppData\Roaming\npm\node_modules\node-red\node_modules@node-red\registry\lib\loader.js
- C:\Users\Admin\AppData\Roaming\npm\node_modules\node-red\node_modules@node-red\registry\lib\index.js
- C:\Users\Admin\AppData\Roaming\npm\node_modules\node-red\node_modules@node-red\runtime\lib\nodes\index.js
- C:\Users\Admin\AppData\Roaming\npm\node_modules\node-red\node_modules@node-red\runtime\lib\index.js
- C:\Users\Admin\AppData\Roaming\npm\node_modules\node-red\lib\red.js
- C:\Users\Admin\AppData\Roaming\npm\node_modules\node-red\red.js
4 May 01:05:16 - [info] Settings file : C:\Users\Admin.node-red\settings.js
4 May 01:05:16 - [info] Context store : 'default' [module=memory]
4 May 01:05:16 - [info] User directory : \Users\Admin.node-red
4 May 01:05:16 - [warn] Projects disabled : git command not found
4 May 01:05:16 - [info] Flows file : \Users\Admin.node-red\flows.json
4 May 01:05:16 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
4 May 01:05:16 - [info] Starting flows
Ignoring invalid timezone passed to Connection: IST. This is currently a warning, but in future versions of MySQL2, an error will be thrown if you pass an invalid configuration option to a Connection
4 May 01:05:16 - [info] Started flows
4 May 01:05:16 - [info] [aedes broker:fa484b8951534360] Binding aedes mqtt server on port: 1883
4 May 01:05:16 - [info] [mqtt-broker:ccd1cd629d5fb1f4] Connected to broker: mqtt://192.168.0.169:1883
Looks to me like your httpStatic setting is in a commented section of the settings file.
Try adding */ above it
2 tips.
Please don't post screenshots. We cannot check them in a code editor
Use a proper code editor to view the js file (e.g. VSCode) and you will see much clearer what is going on.
As @E1cid points out, the httpStatic entry is commented out due to a bad edit but since you are using notepad, you cannot see it.
Oh, one more tip, when posting code and logs, please wrap them in a code fence.
canned text:
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil
icon.
Thanks all for your valuable support.my problem solved.
thank you
