Include local graphic on a template page
Within an NR project, graphics (png/jpeg) should also be displayed to the user on a page within a descriptive text.
Certainly not rocket science, but I can't find the connection of path/filename between the general project area /home/pi/project and the NR flows.
The 'settings.json' is default, so not changed.
To display the page, a template with <style/> and <div/> is used, e.g:
   <div>
      <p>
   Lorem ipsum dolor sit amet, consectetuer adipiscing elit.<br/>
       <img title="German" src="/docs/flagDE.png" align="bottum">
       <!-- /home/pi/project/docs/flagDE.png -->
   Nullam dictum felis eu pede mollis pretium. Integer tincidunt.
      </p>
   </div>
The specifications for <img src="????"> are my problem.
Where can I find an overview of how the path/file structures are related between NR nodes/flows and other project resources on the pi file system as shown above?
Which settings are required to include such graphics in the text?
I think you have to change.
this might help....
You need to change httpStatic in settings.js to the absolute pathname of your static content directory.
For example
httpStatic: '/home/pi/.node-red/node-red-static/', //single static source
And to use an image in that directory you would have
<div>
   <img src="/mypic.jpg">
</div>
Thanks to @jbudd and @smanjunath211
Yes, changing the settings.json with httpStatic: '/home/pi/', did the job.
Restarting node-red logs that with:
17 Jun 14:23:20 - [info] HTTP Static : /home/pi > /
Looks a bit strange, but works...
A first check was OK:
http://raspberryIP:1880/project/docs/flagDE.png
displaying the flag symbol as expected.
The 'template' has:
    <img title="German" src="/project/docs/flagDE.png" align="bottum">
    <!-- file location of the png    /home/pi/project/docs/flagDE.png -->
Great help to remind about the importance of the settings.json.
A general overview of the path/file structure would make the relationships easier to understand ... but I have not found one
You should use a subdirectory of /home/pi/.node-red since everything in the directory becomes visible to the Node-red web page.
But with that the whole NR installation "becomes visible to the Node-red web page." ... isn't it better to have httpStatic: '/home/pi/nrprojects/ and have the indivdual projects below that?
Well I did say to use a subdirectory of .node-red.
On my Pi I have httpStatic: '/home/pi/.node-red/node-red-static',
Sorry I don't know a more appropriate wording but I am sure it exists.
I think I initially said "visible in the browser" but when I tested it with /home/pi/mysecretpassword.txt, instead of displaying "Password1" in the browser, the url 192.168.1.11:1880/mysecretpassword.txt opened up a download dialog. Either way my password is now out there in public!
I don't use projects so I can't comment.
Got it! :+1:
