Implement python code
Newbie here.
Can some one help me implement this python code thru node-red?
import json
import requests
class xComfortAPI:
def init(self, url, username, password, verbose=False):
Class to access a Smart Home Controller (SHC) via its web API.
:param url: the URL of the SHC, for example: http://my_home.dyndns.org:8080
:param username: normally "admin" - the user you normally use to log on to the SHC web page
:param password: the password for the user
self.url = url
self.username = username
self.password = password
self.verbose = verbose
self.session_ID = ''
self._get_session_id()
if self.verbose:
print('Got session id "', self.session_ID, '"', sep='')
def _get_session_id(self):
	Logs in to the SHC and gives us a session ID cookie that is authenticated and we reuse to make our JSON RPC calls
	:return: session ID cookie(string)
	headers = {'User-Agent': 'Mozilla/5.0'}
	session = requests.Session()
	try:
		session.get(self.url)
	except Exception as err:
		if 'failed to respond' in str(err):
			print('ERROR:', self.url, 'did not respond to our connection attempt. Please check your URL address\nAborting...')
			exit(1)
		else:
			print('ERROR:', err, '\nAborting...')
			exit(1)
	response = session.post(self.url, headers=headers, auth=(self.username, self.password))
	if response.status_code != 200:
		if response.status_code == 401:
			print('Invalid username/password\nAborting...')
			exit(1)
		else:
			print('Server responded with status code', str(response.status_code), '\nAborting...')
	else:
		self.session_ID = requests.utils.dict_from_cookiejar(session.cookies)['JSESSIONID']
def query(self, method, params=['', '']):
	Sends query to SHC's JSON RPC interface
	:param method: the JSON RPC method
	:param params: parameters for the JSON RPC method (defaults to list of two empty string)
	:return: dict of response from SHC
	json_url = self.url + '/remote/json-rpc'
	data = {
		"jsonrpc": "2.0",
		'method': method,  # Settings/getSystemInfo
		'params': params,
		'id': 1
	headers = {
		'Cookie': 'JSESSIONID=' + self.session_ID,
		'Accept-Encoding': 'gzip, deflate',
		'Content-Type': 'application/json',
		'Accept': 'application/json, text/javascript, */*; q=0.01',
	try:
		response = requests.post(json_url, data=json.dumps(data), headers=headers).json()
	except ValueError as err:
		if err == 'Expecting value: line 1 column 1 (char 0)':
			print('The SHC gave an invalid response. Most likely, this is due to an incorrect URL in your INI-file')
			print('Please verify that your URL is of the format "http://IP:port", or just "http://IP" if you use default port 80')
		exit(1)
	if 'result' not in response:
		response['result'] = [{}]  # In case we have a zone without devices for example
		if self.verbose:
			print('-> NO datapoints returned')
	elif self.verbose:
		print('->', len(response['result']), 'datapoints returned')
	return response['result']
def get_zone_devices(self):
	Getting all zones and functions
	:return: list of zones with all devices in each zone
	zone_list = self.query('HFM/getZones')  # Returns a list of dicts in this case
	for zone in zone_list:
		zone.pop('virtual', None)
		zone.pop('mainIndoorTemperature', None)
		zone['devices'] = self.query('StatusControlFunction/getDevices', params=[zone['zoneId'], ''])
	return zone_list
@staticmethod
def print_zones(zones):
	Prints all zones and their devices in human readable form
	Static method
	:param zones:
	for zone in zones:
		print(zone['zoneName'], '(' + zone['zoneId'] + ')')
		for device in zone['devices']:
			if 'name' in device:
				print('\t{:<55}{:>10}{}'.format(device['name'], device['value'], device['unit']))
def show_diagnostics(self):
	Prints the SHC diagnostics info
	all_diagnostics = self.query('Diagnostics/getAllSystemStates')
	print('\n### SHC diagnostic information ###')
	for diagnostics in all_diagnostics:
		print(diagnostics['statusValue'])
	print('\n')
def switch(self, zone, dev_id, state):
	Turns off a device
	:param dev_id: the SHC ID of the device (like 'xCo:5355820_u0')
	:param zone: the zone the device is in (like 'hz_1')
	:param state: 'on', 'off' or '' - if '' it means "switch to other" (on if off, off if on)
	:return: True if successful, False otherwise
	if not state == 'on' and not state == 'off' and not state == '':
		print('Error: switch() state must be "on", "off" or "" (blank), not "' + str(state) + '"')
		exit(1)
	result = self.query('StatusControlFunction/controlDevice', params=[zone, dev_id, 'off'])
	if not result['status'] == 'ok':
		return False
	else:
		return True
What does that mean? Tell us instead about what you would like to achieve
Does the code work as is if you run it outside of Node-RED?
