Hello everyone,
Is it possible to import an excel file (xlsx, xlsm) into node-red and extract data from it without precising the path of said file ?
Almost like a "drag and drop your file here" on the dashboard.
Thanks in advance,
Hello everyone,
Thanks in advance,
There are nodes you can use, you could also use the readExcelFile npm library directly in a function node if you prefer.
Thank you for your answer ! But I'm pretty new to node red and I don't know how to use an npm library in a function node, do you perhaps have an example ? (Sorry !)
Also, can it be done with no access to the internet ?
Thanks in advance !
see this article for using npm modules in a function node
Start by looking through the "flows" section of this site and search for excel to see if you can find a suitable node. The use of an npm library is a bit more of an advanced topic and probably not so useful if you don't know any JavaScript.
I could be wrong but I haven't seen any nodes that support drag and drop on Dashboard.
The spreadsheet-in node can read excel files, works quite well. This could be used with a file upload in dashboard, or any other way you read a file within node-red
There is an example flow using dropzone js here: https://flows.nodered.org/flow/c70d0b4c54b583cf30c7e989b74feb68
Thank you for your reply ; I did try to use the spreadsheet-in nodes, however I can't get them to work...
The first time I deploy the flow, nothing happens and the debug nodes return nothing, and if I try to change the settings of the nodes (for instance, the output and encoding of the "read file" node, or the range of cells in the "sheet to json" node) : whenever I try to deploy, it says "lost connection to the server" and basically crashes...
Did I set up the nodes wrong ?
Sorry and thank you for your help !
Node-RED version : v3.0.2
Node.js version : v18.15.0
"id": "8c0b80d407f06452",
"type": "book",
"z": "2d72e3a85743de48",
"name": "test.xlsm",
"raw": false,
"x": 720,
"y": 220,
"a95ed85a5a8d87ae"
"id": "a95ed85a5a8d87ae",
"type": "sheet",
"sheetName": "feuille1",
"x": 890,
"y": 220,
"da6e244de92f56d6",
"b54fb66e1296fa18"
"id": "da6e244de92f56d6",
"type": "cell",
"address": "A1",
"dataType": "w",
"x": 1030,
"y": 220,
"ce1511dba0046374"
"id": "8083a45afd8af295",
"type": "file in",
"filename": "C:\\Downloads\\test.xlsm",
"filenameType": "str",
"format": "utf8",
"chunk": false,
"sendError": false,
"encoding": "none",
"allProps": false,
"x": 390,
"y": 220,
"8c0b80d407f06452"
"id": "8b9eb5ad0c063de7",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 200,
"y": 220,
"8083a45afd8af295"
"id": "ce1511dba0046374",
"type": "debug",
"name": "debug 15",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 1160,
"y": 220,
"id": "b54fb66e1296fa18",
"type": "sheet-to-json",
"raw": "false",
"range": "A1:B2",
"header": "default",
"blankrows": false,
"x": 1030,
"y": 280,
"2e73542474bd8c3c"
"id": "2e73542474bd8c3c",
"type": "debug",
"name": "debug 16",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1180,
"y": 280,
Set the read file node to a single Buffer Object and try again.
Interesting, I might have a look at that some time. ![]()
That worked! Thanks
Now to see about that drag and drop
