Import psycopg2 error when running python node
I am trying to execute python script which invokes postgress database connection on a remote machine and I see following error, though the psycopg2 package is installed as part of python packages. I have installed "node-red-contrib-python3-function" , "node-red-contrib-python-function" and "node-red-contrib-pythonshell"
msg.payload : string[136]
string[136]
Traceback (most recent call last):
File "dbconnect.py", line 5, in
import psycopg2
ImportError: No module named psycopg2
I see this error if I use either of "python node" or pythonshell or "exec" node.
Any pointers in this regard to unblock me.
And it works from the commandline ?
Why call a python script? Why not query the database from node red?
There are about 6 nodes for postgres (search postgres here)
e.g. This one
Yes, it works from command line
is Node-RED running in the same environment as your command line user ? Ie are the python packages available globally - or just to your user. ?
Yes, its running on same environment as command line user.
Infact I have my python script placed at this location.
/var/lib/docker/overlay2/18abcc8e24afc641fa13752e9d5477f79d5fe2d2d9a643496b1473995599fd9b/merged/usr/src/node-red
I execute the python script as "root" user, which is working fine from command line.
From node red, I get the import error(*"ImportError: No module named psycopg2")not sure whats the missing link here.
Should I have this file in different path?
The reason why I am using python script to connect to postgres DB as I need to pass certificate and key file to connect to my database.
As I don't use postgres nor the available nodes so I cant answer whether they support that i'm afraid.
However, it would be good for the community if they did. Perhaps give them a try & feedback a request/issue via github?
Sure, I will do that.
My current issue to run python script that connects to postgres is running into "psycopq2" import error, that I need to get it resolved to make me get going.
I figured out the problem, the problem is the docker image of node-red do not contain "python-psycopg2" packages, you can verify it by getting into node-red shell.
  1. docker exec -it mynodered /bin/bash
    I ran it manually, it failed again.
node-red@77f884ce09a9:~$ python dbconnect.py
import psycopg2
However the global python present in my system had this when I executed it as root.
How can I add this "python-psycopg2" package to node-red docker image.
I tried even building it, it did not help.
I did modify the Dockerfile to install "psycopg2 and tried to build the docker image of "node-red" it did not help.
RUN apt-get install python-psycopg2
Step 10/14 : RUN apt-get install python-psycopg2
---> Running in 506c3d9919f6
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
The command '/bin/sh -c apt-get install python-psycopg2' returned a non-zero code: 100
Any help in this regard is appreciated.
You need to be the root user to run apt-get. I think the following will help.
(Please pick if you want to continue this discussion here or in slack... not going to split it over both places)
USER root
USER node-red
I tried as you suggested, look like its unable to pick the package.
Step 3/4 : RUN apt-get install python-psycopg2
---> Running in 7a41d497a588
Reading package lists...
Building dependency tree...
Reading state information...
E: Unable to locate package python-psycopg2
Am I missing something, I tried to install "pip" even that had run into same error.
I'm just making educated guesses as it isn't something I've ever done.
A quick google search finds lots of threads talking about installing psycopg2 into a Docker image. I suggest you go read those threads and follow their advice based on actual experience.
Thanks, I forgot to update this thread. I got this issue resolved.
I followed these steps.
  1. Install node-red
  2. login as root using node-red CLI
  3. Add the required packages
    apt-get update
    apt-get install -y python-pip
    apt-get install -y python-psycopg2
Create a docker build with these packages in it and re-install node-red.
how did u login as root?
