In node red how to get the number of TCP connections or websocket connections count to create the dashboard.
Can you explain a bit more ? The node-red-dashboard works without you needing to know this.
The ui_control node will give you a message whenever a client connects, disconnects etc if you need that.
The TCP node does provide a status with the number of connections, that can be read by the status node.
I want to show the number of connections happened in dashboard, how to show??
which connections ? connections from the dashboard ? connections from some tcp port you have mentioned > - please help by explaining more detail what you want.
I have some devices those are connected to tcp. i want to see those connected devices count in dashboard. is it possible .please let me know if you want any details.
If there is a clever command line tool you could use then you can call that using an exec node and then parse the output.
i Have 8 connections as of now i want to see those connection in dashboard.is it possible
so use the status node as I first suggested.
But Status node is not from dashboard . it's from input side. i tried that.
... so is the tcp node... so tcp node -> status node -> change msg as you require for dashboard -> ui_text node (or whatever you want on dashboard)
Can we get the number of dashboard websocket connections through ui-control node?
If you count them yourself yes.
