I wanted 3 drop down list, based on 1st drop down selection 2nd drop down list options should come, and based on 2nd 3rd drop down list should come. The payload is
"controller": "S000",
"sensorConf": [{
"sensor": "s"
"sensor": "s2"
"controller": "S001",
"sensorConf": [{
"sensor": "s3"
"sensor": "s4"
So after calling API I will get below response, So I placed one drop down node for controller id seletion(ex c1), after that I wanted to choose from array of sensorConf sensor parameter( ex s3).
In the above flow how to save the selection result for each request by user. As I have to request again API to fetch the sensorConf deatils(sensor).
Which variable I have to use context variable,Flow variable , Global variable . If I use global then it is global not based on user selection.
