I'm trying to set the timezone in my node-red to Australia/Perth.
The node-red is running on Ubuntu 22.04, the system timezone was set to Australia/Perth. This is the output of date command.
However, in node-red, the timezone is Australia/Sydney.
I also tried to add process.env.TZ=Australia/Perth but still no luck. I restart my node-red everytime I change the settings.js and system time.
The wrong timezone makes the x-axis of my line chart incorrect, the x-aixs is also showing Sydney time instead Perth. Any help would be appreciated!
Thanks!
How are you running node-red (docker container?)
What do you see if you use an exec node to run the date command?
If you press ctrl-shift-p and enter "system info", what does it reveal?
Colin
4
Where is the value shown coming from?
Can you try a different browser?
This came from an timestamp inject node.
I just realize that setting up process.env.TZ works, the timezone printed in the node-red console and the axis of charts use the browser timezone.
Thank you all for helping
