Increment String
hi I need Increment String by one but I cant
sow I convert to number for incremented but nothing
and this
var id = Number(msg.payload[0]._id);
id++;
msg.payload[0].ack_id = (id).toString();
node.send(msg);
not work
any help
This is because your id string contains letters and not just numbers. So the Number() method returns NaN not a number.
Johannes
Edit here is a link that explains this behavior of the Number() Method https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Number
If you are using it just to confirm receipt, why not simply return the _id (i.e. why do you have to increment it?)
oh yes am wrong I thought HEX valeu
this NEXT Record from MongoDB
so I need find this id into database for check its present or not
Ok,so is that an automatic ID or does your systems generate it?
If it's automatically generated by mongo I'm not certain you can guarantee the next id will be hex+1
this Auto ID generated by mongodb when store any thing
Then I'm struggling to understand the logic. Anyhow, assuming it's always alphanumerically greater then can't you select next record(s) where _id I'd greater than _id?
E.g...
db.products.find({_id: {$gt: ObjectId("4fdbaf608b446b0477000142" )}}).sort({_id:1}).limit(1);
ok I am solved with add UUID node generator to any new incoming event and not ACK type of msg
before stored in dB
yes its logic to work
but I see this error
Actually, not sure how you'd do this ina function node.
Normally in a nodejs project ObjectId is imported
E.g. var ObjectId = require('mongodb').ObjectID;
Does the mongo nodes have a find node? Or a means of accessing ObjectId?
Sorry, I don't know how to help here.
