I have a situation where I am sending a HTTP Post command to a series of IP devices.
The IP devices have sequential IP address
For example:
192.168.1.1
192.168.1.2...
192.168.1.100
I have tried the attached flow , although the debug shows it is sending out the correct msg.url as expected the commands are not being executed in the HTTP node.
Any suggestions?
[{"id":"1e8207bc.ac5ba8","type":"function","z":"2d9d8e01.84ef32","name":"","func":"var counter = msg.payload;\nvar TxCh =global.get('TXChSelected');\nvar temp = global.get(\"HddsxRxSelected\");\nvar RX_IP = 'http://172.31.3.';\nvar CGI_switch_command = '/cgi-bin/query.cgi?cmd=rxswitch:';\n\n\nif(counter <=10){\n msg.payload = counter++;\n msg.url = RX_IP+counter+CGI_switch_command+'00'+TxCh;\n return msg;\n}\n\n\n","outputs":1,"noerr":0,"x":750,"y":300,"wires":[["9f34c62f.36f478","63630687.c39168","d252a40e.5d1058"]]},{"id":"5a835f2d.c7a11","type":"delay","z":"2d9d8e01.84ef32","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":820,"y":200,"wires":[["1e8207bc.ac5ba8"]]},{"id":"f2a266af.4562d8","type":"inject","z":"2d9d8e01.84ef32","name":"","topic":"","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":590,"y":300,"wires":[["1e8207bc.ac5ba8"]]},{"id":"9f34c62f.36f478","type":"function","z":"2d9d8e01.84ef32","name":"++","func":"\n msg.payload = msg.payload+1;\n return msg;\n\n\n","outputs":1,"noerr":0,"x":690,"y":200,"wires":[["5a835f2d.c7a11"]]},{"id":"63630687.c39168","type":"http request","z":"2d9d8e01.84ef32","name":"Switch RX","method":"POST","ret":"txt","url":"","tls":"","x":950,"y":300,"wires":[[]]},{"id":"d252a40e.5d1058","type":"debug","z":"2d9d8e01.84ef32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"url","x":890,"y":380,"wires":[]}]
