When using an "inject node" with msg.payload set to Number in the drop down menu, if the value is set to Infinity Node-RED will place a Triangle on that node and state that the property is invalid. Every time I try to deploy, it will warn me:
The workspace contains some nodes that are not properly configured:
[Functions] Infinity (inject)
Are you sure you want to deploy?
