I am trying to get data from influxdb but i get request timed out error.
Could you kindly help
[{"id":"66b9a2774e39b79b","type":"http in","z":"95c455e1841b6220","name":"","url":"/api/getP1LastOneHrData/:chipID/","method":"get","upload":false,"swaggerDoc":"","x":230,"y":640,"wires":[["038f0a51a45ffd06","c8cf01b3b751a339"]]},{"id":"038f0a51a45ffd06","type":"change","z":"95c455e1841b6220","name":"","rules":[{"t":"set","p":"params","pt":"msg","to":"req.params.chipID","tot":"msg","dc":true}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":640,"wires":[["dde4efb6605fdb6a","c68ea5b74fa2739d"]]},{"id":"dde4efb6605fdb6a","type":"function","z":"95c455e1841b6220","name":"","func":"msg.payload={\n"params": {\n "chipID": msg.params\n \n}}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":,"x":640,"y":640,"wires":[["f557815bba7e6257","dbd701e40a65496c"]]},{"id":"f557815bba7e6257","type":"function","z":"95c455e1841b6220","name":"Query","func":"var chipID = msg.payload.params.chipID\n\nmsg.query =
from(bucket: \"sensorcommunity\")\n |> range(start: -1h)\n |> filter(fn: (r) => r[\"_measurement\"] == \"datapoints\")\n |> filter(fn: (r) => r[\"_field\"] == \"SDS_P1\")\n |> filter(fn: (r) => r[\"node\"] == \"${chipID}\")\n |> yield();\n\nreturn msg;\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":,"x":790,"y":640,"wires":[["8ab701228c25b75f","c1b943296dde3f20"]]},{"id":"8ab701228c25b75f","type":"influxdb in","z":"95c455e1841b6220","influxdb":"ecb180858f6fa706","name":"Influx_Read","query":"","rawOutput":false,"precision":"","retentionPolicy":"","org":"3fab497f8770d3ed","x":950,"y":640,"wires":[["4962b18d68d25d61","af452db43ee79675"]]},{"id":"4962b18d68d25d61","type":"function","z":"95c455e1841b6220","name":"","func":"\n// msg.payload=[{\n// "series": [msg.payload[0]._field],\n// "data":[ msg.payload.map(obj => {\n// return {\n// x: obj._time,\n// y: obj._value\n// }\n// })\n// ],\n// "labels": [msg.payload[0].node] \n// }];\nmsg.payload = [{\n \n "channel": [msg.payload[0]._field],\n "color": "Black",\n "dataset": [msg.payload.map(obj => {\n return {\n x: obj._time,\n y: obj._value\n }\n })\n ]\n }] \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":,"x":1120,"y":640,"wires":[["cfb7dcbdf680023f"]]},{"id":"cfb7dcbdf680023f","type":"http response","z":"95c455e1841b6220","name":"","statusCode":"","headers":{},"x":1270,"y":640,"wires":},{"id":"ecb180858f6fa706","type":"influxdb","hostname":"127.0.0.1","port":"8086","protocol":"http","database":"database","name":"Influx_Read","usetls":false,"tls":"","influxdbVersion":"2.0","url":"http://20.234.100.130:8086/","rejectUnauthorized":true,"credentials":{}}]
