Influxdb 2.0 Error Data Type
Hi, I'm using node-red-contrib-influxdb (0.5.0) to pipe data into an Influxdb V2.
After the updateto V2 I'm facing the following error:
Error: 500 Internal Server Error : {"code":"internal error","message":"unexpected error writing points to database: partial write: field type conflict: input field "ITE06_H" on measurement "ITE06" is type integer, already exists as type float dropped=1"}
It seems to be a problem with the datatype. If i.e. the temperature value is 20 it's an integer, 20.1 a float. But the table only supports one type.
Is there a way to convert numbers befor sending them to influxdb?
This error occures after updating node-red-contrib-influxdb to 0.5.0 and influxdb to V2.
Thank you very much for any advise!
Martin
You could always use a parseInt() or round() on the number
Changing/rounding to integer is easy. I'm trying to write temperature to Influx 1.8 and have exactly the same issue. 20 degrees set the field as integer, 20.1 as float. I would like to preserve decimal to have more precision.
I've tried to use .toFixed(2) but that change the type to string, which is not what I want.
So how to enforce float type even with values without decimal?
I wonder whether this is a problem with the new version of the influx node. I have never had any problems like this with the previous versions.
In fact looking at https://github.com/mblackstock/node-red-contrib-influxdb/issues/49 it seems the previous version did not write integer types at all, so I suspect they have added that feature, with the result that now it is apparently possible to create field with integer type, and then you are stuck.
I see this problem has just been added as an issue, unless that issue has been submitted by someone here. https://github.com/mblackstock/node-red-contrib-influxdb/issues/71
Your second link should probably point to https://github.com/mblackstock/node-red-contrib-influxdb/issues/71
I've commented that issue for mode details.
I opened #71 and it was already fixed by owner.
Hopefully he'll release it in short time.
Correct, thanks for noticing that, have corrected my original post.
I you want to install it direct from the git repository you can go to your .node-red folder and run
npm install mblackstock/node-red-contrib-influxdb
and restart node-red.
When it has been released, or if you want to go back to the issued version go to that folder and run
npm remove node-red-contrib-influxdb
npm install node-red-contrib-influxdb
Thanks for reporting this, and sorry for the trouble.
I did a quick release to add support for integer values using strings as mentioned in the issue comments. To write an integer 10, use a string with an 'i' suffix: '10i', to write a float 10.0 use a number: 10 or 10.0.
I plan to update the docs and add some more tests soon. Let me know if you see any other problems by raising an issue on github.
Thanks for the work on this node, I was wondering recently whether I should contemplate migrating to v2, now at least it should not be problematic at the node-red end.
