InfluxDB connection error
You appear to be asking for only data in the future, though I would not expect that to give the error you are seeing.
Are you using the influxdb Out node to write data successfully? Can you export the function node, InfluxDB In node and the Influxdb Out node that works please and paste them here.
See this post for more how to post flows - How to share code or flow json
