Let me know if this the correct information.  Thank you again!-
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
3 Jul 08:32:17 - [info]
Welcome to Node-RED
3 Jul 08:32:18 - [info] Node-RED version: v0.20.5
3 Jul 08:32:18 - [info] Node.js version: v10.15.3
3 Jul 08:32:18 - [info] Linux 4.14.98+ arm LE
3 Jul 08:32:28 - [info] Loading palette nodes
3 Jul 08:33:04 - [info] Dashboard version 2.14.0 started at /ui
3 Jul 08:33:11 - [info] Settings file : /home/pi/.node-red/settings.js
3 Jul 08:33:11 - [info] Context store : 'default' [module=memory]
3 Jul 08:33:11 - [info] User directory : /home/pi/.node-red
3 Jul 08:33:11 - [warn] Projects disabled : editorTheme.projects.enabled=false
3 Jul 08:33:11 - [info] Flows file : /home/pi/.node-red/flows_Garden_Bed_1.json
3 Jul 08:33:13 - [warn]
your credentials.
3 Jul 08:33:13 - [info] Starting flows
3 Jul 08:33:22 - [info] Started flows
3 Jul 08:33:22 - [info] Server now running at http://127.0.0.1:1880/
3 Jul 08:33:23 - [info] [mqtt-broker:c5c9580d.04686] Connected to broker: mqtt:/
