Hi and welcome.
All depends on timing you wish after the flow finishes.
here are 2 examples of possible solutions
[{"id":"b2cd414314d6cb69","type":"inject","z":"452103ea51141731","name":"stop","props":[{"p":"reset","v":"true","vt":"bool"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":3540,"wires":[["8a582f90b300bcda"]]},{"id":"8a582f90b300bcda","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"finished","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":3540,"wires":[["652b0d3ab2b55b71"]]},{"id":"652b0d3ab2b55b71","type":"delay","z":"452103ea51141731","name":"simulate flow time","pauseType":"random","timeout":"6","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"4","randomLast":"6","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":470,"y":3480,"wires":[["a00362e6d6b9affd"]]},{"id":"d27964c10afa5663","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"finished","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":3420,"wires":[["652b0d3ab2b55b71"]]},{"id":"a00362e6d6b9affd","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"delete","p":"finished","pt":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":3420,"wires":[["a80776679f1372bf"]]},{"id":"b7800bad515d4db1","type":"switch","z":"452103ea51141731","name":"","property":"finished","propertyType":"flow","rules":[{"t":"istype","v":"undefined","vt":"undefined"}],"checkall":"true","repair":false,"outputs":1,"x":230,"y":3420,"wires":[["d27964c10afa5663"]]},{"id":"a80776679f1372bf","type":"debug","z":"452103ea51141731","name":"debug 107","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":690,"y":3460,"wires":[]},{"id":"49588608ed5577a0","type":"inject","z":"452103ea51141731","name":"test","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"2","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":3420,"wires":[["b7800bad515d4db1"]]},{"id":"981b57957a5a55ec","type":"inject","z":"452103ea51141731","name":"stop","props":[{"p":"reset","v":"true","vt":"bool"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":3580,"wires":[["cdec8f187c0b9749"]]},{"id":"cdec8f187c0b9749","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"delete","p":"finished","pt":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":3580,"wires":[[]]},{"id":"ae660bb3eba7402a","type":"inject","z":"452103ea51141731","name":"reset","props":[{"p":"reset","v":"true","vt":"bool"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":3320,"wires":[["eade73defeaf2348"]]},{"id":"eade73defeaf2348","type":"trigger","z":"452103ea51141731","name":"","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":320,"y":3320,"wires":[["27cc2aae95087f4f"]]},{"id":"1c0bb849507f28ad","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"test","payloadType":"str","x":170,"y":3260,"wires":[["eade73defeaf2348"]]},{"id":"27cc2aae95087f4f","type":"delay","z":"452103ea51141731","name":"simulate flow time","pauseType":"random","timeout":"6","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"4","randomLast":"6","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":390,"y":3220,"wires":[["a15b280990b32f57"]]},{"id":"a15b280990b32f57","type":"function","z":"452103ea51141731","name":"function 17","func":"return [msg,msg];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":490,"y":3260,"wires":[["543d77c6f929e577"],["eade73defeaf2348"]]},{"id":"543d77c6f929e577","type":"debug","z":"452103ea51141731","name":"debug 106","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":690,"y":3260,"wires":[]}]
