Inject repeat function
You are using the [repeat] function of [inject] to receive data every 15 minutes from the [modbus-flex-sequencer node].
You should receive data from a total of 10 devices through modbus. When you first deploy and run Nordred, the data for 10 devices is transmitted well. However, in the second iteration, only data for device 1 is transmitted. Do you know why this is the case?
Here is my nodered code.
        "id": "4e7bc0d34e695226",
        "type": "crontinject",
        "z": "53c7c787661b774e",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "900",
        "crontab": "",
        "once": true,
        "onceDelay": "2.1",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "crontiMethod": "",
        "crontiArgs": "[]",
        "inputs": 0,
        "hasButton": true,
        "x": 250,
        "y": 280,
                "498e5f3556ef1628"
        "id": "498e5f3556ef1628",
        "type": "modbus-flex-sequencer",
        "sequences": [
                "name": "1",
                "unitid": "1",
                "fc": "FC4",
                "address": "0",
                "quantity": "44"
                "name": "2",
                "unitid": "2",
                "fc": "FC4",
                "address": "0",
                "quantity": "44"
                "name": "3",
                "unitid": "3",
                "fc": "FC4",
                "address": "0",
                "quantity": "44"
                "name": "4",
                "unitid": "4",
                "fc": "FC4",
                "address": "0",
                "quantity": "44"
                "name": "5",
                "unitid": "5",
                "fc": "FC4",
                "address": "0",
                "quantity": "44"
                "name": "6",
                "unitid": "6",
                "fc": "FC4",
                "address": "0",
                "quantity": "44"
                "name": "7",
                "unitid": "7",
                "fc": "FC4",
                "address": "0",
                "quantity": "44"
                "name": "8",
                "unitid": "8",
                "fc": "FC4",
                "address": "0",
                "quantity": "44"
                "name": "9",
                "unitid": "9",
                "fc": "FC4",
                "address": "0",
                "quantity": "44"
                "name": "10",
                "unitid": "10",
                "fc": "FC4",
                "address": "0",
                "quantity": "44"
        "server": "fd93d7ae22777e95",
        "showStatusActivities": false,
        "showErrors": false,
        "showWarnings": true,
        "logIOActivities": false,
        "useIOFile": false,
        "ioFile": "",
        "useIOForPayload": false,
        "emptyMsgOnFail": false,
        "keepMsgProperties": true,
        "delayOnStart": false,
        "startDelayTime": "100",
        "x": 540,
        "y": 280,
                "13b3612ca129149e",
                "09bc7395f5bb11d3",
                "5708a8886f25e57c"
        "info": "Server 세팅에서 Timeout(ms)이 1000으로 설정시 전력량계 통신이 5~6개 통신시 timeout 에러 발생\r\nTimeout(ms)를 2000으로 세텡하고 시험시 현재 10대 까지 timeout 에러 없슴\r\n"
        "id": "13b3612ca129149e",
        "type": "function",
        "name": "modbus노드에 따른 site등록",
        "func": "var siteID = 1;\nvar siteName = \"더콘솔\";\nvar query = \"SELECT * FROM tb_site WHERE SITE_CODE='\" + siteID + \"' AND SITE_NAME='\" + siteName + \"';\";\nmsg.topic = query;\nmsg.siteID = siteID;\nmsg.siteName = siteName;\nflow.set(\"siteID\",siteID);\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 900,
        "y": 240,
                "91d483450409bd58"
        "id": "91d483450409bd58",
        "type": "mysql",
        "mydb": "20fc62db2276ec96",
        "x": 1065,
        "y": 240,
                "faac45c8d62764be"
        "l": false
        "id": "faac45c8d62764be",
        "type": "function",
        "name": "분기",
        "func": "if (msg.payload.length === 0) {\n    msg.siteExists = false;\n} else {\n    msg.siteExists = true;\n}\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1170,
        "y": 240,
                "d15068fdeca717e6"
        "id": "d15068fdeca717e6",
        "type": "switch",
        "property": "siteExists",
        "propertyType": "msg",
        "rules": [
                "t": "false"
                "t": "true"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 1330,
        "y": 240,
                "3351491a86e42bec"
                "cc0e75ac470adc02"
        "id": "3351491a86e42bec",
        "type": "function",
        "name": "site 자동등록",
        "func": "var siteID = flow.get(\"siteID\");\nvar siteName = flow.get(\"siteName\");\n\nvar query = \"INSERT INTO tb_site (SITE_CODE,SITE_NAME) values (?,?);\";\nmsg.topic= query;\nmsg.payload = [siteID,siteName];\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1630,
        "y": 220,
        "id": "cc0e75ac470adc02",
        "type": "function",
        "name": "저장된 Device 자동등록",
        "func": "var deviceID = msg.unitid;\nvar siteID = msg.siteID;\n\nvar query = \"INSERT INTO tb_mtr_info (SITE_CODE, MTR_NO) VALUES (?, ?) ON DUPLICATE KEY UPDATE MTR_NO = MTR_NO;\";\nmsg.topic = query;\nmsg.payload = [siteID, deviceID];\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1670,
        "y": 260,
                "be3aa5432905b4a2"
        "id": "be3aa5432905b4a2",
        "type": "mysql",
        "x": 1815,
        "y": 260,
        "l": false
        "id": "8f37c0dccbfb0682",
        "type": "mysql",
        "x": 1175,
        "y": 300,
                "26578295ec04d73d"
        "l": false
        "id": "cf301ffcf9c41f96",
        "type": "function",
        "name": "function 14",
        "func": "var date = new Date();\nvar month = date.getMonth() + 1;\nvar day = date.getDate();\n\nif (day == 1) {\n    var realday = \"Mon\";\n} else if (day == 2) {\n    realday = \"Tue\";\n} else if (day == 3) {\n    realday = \"Wed\";\n} else if (day == 4) {\n    realday = \"Thur\";\n} else if (day == 5) {\n    realday = \"Fri\";\n} else if (day == 6) {\n    realday = \"Sat\";\n} else if (day == 0) {\n    realday = \"Sun\";\n}\n\n// 날짜, 시간 값을 두 자리수로 표현하도록 수정합니다.\nvar format_date = date.getFullYear() + \"-\" + (\"0\" + month).slice(-2) + \"-\" + (\"0\" + date.getDate()).slice(-2) + \" \" +\n                (\"0\" + date.getHours()).slice(-2) + \":\" + (\"0\" + date.getMinutes()).slice(-2) + \":\" +\n                (\"0\" + date.getSeconds()).slice(-2);\n\nvar siteID = flow.get(\"siteID\");\n\n// 반복문으로 데이터베이스에 저장\n    var deviceID = msg.payload.DevID;\n    var Active_PowerEnergy = msg.payload.Active_PowerEnergy;\n    var Reactive_PowerEnergy = msg.payload.Reactive_PowerEnergy;\n    var A_Phase_Voltage = msg.payload.A_Phase_Voltage;\n    var B_Phase_Voltage = msg.payload.B_Phase_Voltage;\n    var C_Phase_Voltage = msg.payload.C_Phase_Voltage;\n    var A_Phase_Current = msg.payload.A_Phase_Current;\n    var B_Phase_Current = msg.payload.B_Phase_Current;\n    var C_Phase_Current = msg.payload.C_Phase_Current;\n    var A_Phase_Angle = msg.payload.A_Phase_Angle;\n    var B_Phase_Angle = msg.payload.B_Phase_Angle;\n    var C_Phase_Angle = msg.payload.C_Phase_Angle;\n    var A_Phase_PF = msg.payload.A_Phase_PF;\n    var B_Phase_PF = msg.payload.B_Phase_PF;\n    var C_Phase_PF = msg.payload.C_Phase_PF;\n    var Total_Active_Power = msg.payload.Total_Active_Power;\n    var Total_Reactive_Power = msg.payload.Total_Reactive_Power;\n    var A_Active_Power = msg.payload.A_Active_Power;\n    var B_Active_Power = msg.payload.B_Active_Power;\n    var C_Active_Power = msg.payload.C_Active_Power;\n    var A_Reactive_Power = msg.payload.A_Reactive_Power;\n    var B_Reactive_Power = msg.payload.B_Reactive_Power;\n    var C_Reactive_Power = msg.payload.C_Reactive_Power;\n\n    var query = \"INSERT INTO tb_curr_data (SITE_CODE,MTR_NO,READ_DT,F_CUM_ACT_E,F_CUM_REACT_E,VOLTAGE_A,VOLTAGE_B,VOLTAGE_C,CURRENT_A,CURRENT_B,CURRENT_C,PHI_A,PHI_B,PHI_C,PF_A,PF_B,PF_C,ACT_PWR_T,REACT_PWR_T,ACT_PWR_A,ACT_PWR_B,ACT_PWR_C,REACT_PWR_A,REACT_PWR_B,REACT_PWR_C) VALUES (?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?);\";\n    msg.topic = query;\n    msg.payload = [siteID, deviceID, format_date, Active_PowerEnergy, Reactive_PowerEnergy, A_Phase_Voltage, B_Phase_Voltage, C_Phase_Voltage, A_Phase_Current, B_Phase_Current, C_Phase_Current, A_Phase_Angle, B_Phase_Angle, C_Phase_Angle, A_Phase_PF, B_Phase_PF, C_Phase_PF, Total_Active_Power, Total_Reactive_Power, A_Active_Power, B_Active_Power, C_Active_Power, A_Reactive_Power, B_Reactive_Power, C_Reactive_Power];\n\n    // MySQL 노드로 메시지 전송\n    return msg;\n\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1050,
        "y": 300,
                "8f37c0dccbfb0682",
                "060e7c4d2e72117c"
        "id": "5708a8886f25e57c",
        "type": "function",
        "name": "Save To DB",
        "func": "var values = msg.payload;\nvar combinedValues = [];\nvar floatValues = [];\n\nfor (var i = 0; i < values.length; i += 44) {\n    var devid = msg.unitid;\n    var devValues = values.slice(i, i + 44);\n    combinedValues = [];\n    floatValues = [];\n\n    for (var j = 0; j < 22; j++) {\n        if (j < 2) {\n            combinedValues[j] = (devValues[j * 2 + 1] << 16) + devValues[j * 2];\n            floatValues[j] = combinedValues[j];\n        } else {\n            combinedValues[j] = (devValues[j * 2 + 1] << 16) + devValues[j * 2];\n\n            var buffer = new ArrayBuffer(4);\n            var intView = new Int32Array(buffer);\n            var floatView = new Float32Array(buffer);\n\n            intView[0] = combinedValues[j];\n            floatValues[j] = floatView[0];\n        }\n    }\n\n    // 데이터베이스에 저장하기 위해 msg.payload 생성\n    msg.payload = {\n        DevID: devid,\n        Active_PowerEnergy: floatValues[0].toFixed(4),\n        Reactive_PowerEnergy: floatValues[1].toFixed(4),\n        A_Phase_Voltage: floatValues[2].toFixed(4),\n        B_Phase_Voltage: floatValues[3].toFixed(4),\n        C_Phase_Voltage: floatValues[4].toFixed(4),\n        A_Phase_Current: floatValues[5].toFixed(4),\n        B_Phase_Current: floatValues[6].toFixed(4),\n        C_Phase_Current: floatValues[7].toFixed(4),\n        A_Phase_Angle: floatValues[8].toFixed(4),\n        B_Phase_Angle: floatValues[9].toFixed(4),\n        C_Phase_Angle: floatValues[10].toFixed(4),\n        A_Phase_PF: floatValues[11].toFixed(4),\n        B_Phase_PF: floatValues[12].toFixed(4),\n        C_Phase_PF: floatValues[13].toFixed(4),\n        Total_Active_Power: floatValues[14].toFixed(4),\n        Total_Reactive_Power: floatValues[15].toFixed(4),\n        A_Active_Power: floatValues[16].toFixed(4),\n        B_Active_Power: floatValues[17].toFixed(4),\n        C_Active_Power: floatValues[18].toFixed(4),\n        A_Reactive_Power: floatValues[19].toFixed(4),\n        B_Reactive_Power: floatValues[20].toFixed(4),\n        C_Reactive_Power: floatValues[21].toFixed(4)\n    };\n\n    // 데이터베이스에 저장하는 코드 추가\n    // ...\n}\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 810,
        "y": 300,
                "cf301ffcf9c41f96",
                "c9559f5757bc6e33"
        "id": "09bc7395f5bb11d3",
        "type": "debug",
        "name": "debug 169",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 730,
        "y": 360,
        "id": "fd93d7ae22777e95",
        "type": "modbus-client",
        "clienttype": "tcp",
        "bufferCommands": true,
        "stateLogEnabled": false,
        "queueLogEnabled": false,
        "failureLogEnabled": true,
        "tcpHost": "192.168.0.109",
        "tcpPort": "502",
        "tcpType": "DEFAULT",
        "serialPort": "/dev/ttyUSB",
        "serialType": "RTU-BUFFERD",
        "serialBaudrate": "9600",
        "serialDatabits": "8",
        "serialStopbits": "1",
        "serialParity": "none",
        "serialConnectionDelay": "100",
        "serialAsciiResponseStartDelimiter": "0x3A",
        "unit_id": "0",
        "commandDelay": "1",
        "clientTimeout": "2000",
        "reconnectOnTimeout": false,
        "reconnectTimeout": "2000",
        "parallelUnitIdsAllowed": true,
        "showLogs": true
        "id": "20fc62db2276ec96",
        "type": "MySQLdatabase",
        "host": "127.0.0.1",
        "port": "3306",
        "db": "ndbm",
        "tz": "",
        "charset": "UTF8"
