Hi there, I am attempting to inject a set a data that i received from my WatsonIoT Device and putting it into a continuing chart for display. To make it easier for a test run, I chopped off all but one specific set of data, as follows:
[{"V":2,"T":1573853970884,"Q":0},{"V":21,"T":1573853971900,"Q":0},{"V":94,"T":1573853972915,"Q":0},{"V":64,"T":1573853973930,"Q":0},
...and so forth.
What i am hoping to do is to chop off the Q value, then inject both the value and the timestamp correctly into a chart, since it is coming in from the IoT Device in chunks.
The issue I am having is that i cannot seem to put this data into the chart. I can split the data to get the value only presented, but I'm not sure how to present it together with the timestamp.
Is there a way to properly manipulate the data so it can fit perfectly within a chart when it runs?
