I tryed to install Node-RED using script for Debian:
but install failed.
Update Node.js LTS ✘ Failed to install Node.js - Exit.
OS: Ubuntu MATE 18.04 LTS
Hardware: Raspberry Pi 3 Model B
I found following message in /var/log/nodered-install.log:
gpg: can't connect to the agent: IPC connect call failed
I tryed to install node.js 12.x before installing Node-RED.
refs: https://github.com/nodesource/distributions/blob/master/README.md
curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
sudo apt-get install -y nodejs
After installing node.js 12.x, I retried to install Node-RED using script for Debian:
Install succeeded.
I think this is strange.
Is there something to wrong in the install script for Debian?
