Install missing packages from package.json
Hi, before I opening a Github Issue, I want to ask maybe I am missing something.
I'm looking for a way to implement a new flow on my local environment, and then push the updates to remote Docker deployment.
The only problem is that I have to run npm install in the remote machine, in case I added a new library.
Why not add an option to the Node-Red instance to run npm install on startup?
Take a look at the Projects feature Projects : Node-RED
Is it can install the packages from package.json automatically, on load (and not from the UI)?
Can you install the necessary packages in the docker file?
Yes, but for that, I need to create a custom Dockerfile, and recreate the image if I changed the package.json.
Take a look on my solution:
