Hi, i installed the 3.0.2 of Nodered on my rpi4b via a docker image.
Everything seems to work ok, except i get a strange error in my log in nodered
Error: fatal: detected dubious ownership in repository at '/data/projects/iot_nodered'
To add an exception for this directory, call:
git config --global --add safe.directory /data/projects/iot_nodered
I did a git config --global --add safe.directory /data/projects/iot_nodered, but the error remains.
Looks strange because folder iot_nodered is in my .gitignore file
And my gitconfig is also ok!
[safe]
directory = /data/projects/iot_nodered
Also this history sidebar does not show any changes anymore after a change and deply
Any suggestions ?
Other option is disable the use of git and use the project local, but even that does not work,,,,
Thanks!
Peter
