I'm 100% new to Node-RED, and I have been introduced to Node-RED from Milesight, and intended use is to communicate with LoRa sensors and nodes via LoRa Gateway.
When trying to install the Node-RED dashboard, I get the error message shown below.
Why do I get this error message, and what can I do to be able to install the dashboard successfully?
A quick google search using EAI_AGAIN shows 'EAI_AGAIN means the DNS server replied that it cannot currently fulfill the request.'
Are you running in a Docker container?
What platform is NR running on and what OS?
What version of NR and Node.js (you ca find these in the NR startup log)
