Hi I have a node-red server hosted on a Pi-0-W running a full desktop version of Raspbian stretch. Node-RED was installed and subsiquently updated following the instructions on the Node-Red.org Pi page.
Now i wish to replicate the system on a raspbian-lite based system.
so i have downloaded and verified the raspbian-lite image, burnt it to an sd card,
updated and upgraded, and installed and configured my mqtt broker to autostart.
(after failure #1 i repeated the above and then installed the prerequisits and a scrip polling ble sensors, configured this and ran it to confirm BLE coms were fully up and running with success)
Then I installed Node-Red including systemd start/stop scripts as per the Node-Red.org Pi page. And once up and running i pointed a browser at Node-Red and started using the Pallet Manager to install the extra nodes that my flows use.
Here i hit problems.. On attempting to install the 'node-red-contrib-xiaomi-ble' node, it reported that it had installed, and the new node was initially available in the gui list under Bluetooth iirc.
So I copied in a small flow (18? nodes ) via the clipboard, and had failures on deployment.
After a system restart the BLE node was no longer available in the gui list and an unknown node was circled in red in its place in my flow.
I started by stopping node-red and attempting a cli npm install of the node.
This provided errors indicating a problem with bluetooth-hci-socket.
I attempted to install that and following its github readme libudev-devvia apt-get in advance.
the npm install of bluetooth-hci-socket, fell back on a recompile which raised many exceptions based on depreciated references and too ultimately failed.
Im kinda stuck now .. my googlefu has failed me and im sat in disbelief that no one else has attempted to host node red on a version of raspbian lite using the `xiaomi-ble node
i have installed and verified 2 x raspbian lite images onto 2 x 16gb sdhc cards and run into the same stumbling block.
On checking the /var/log/nodered-install.log there are many of simmilar exceptions listed as i witnessed durring my failed npm installation attempts.
Can i host node-RED on raspbiaan-Lite??
> Blockquote**************************************
Started : Sun 10 Feb 13:47:10 GMT 2019
Running for user pi at /home/pi
Failed to stop nodered.service: Unit nodered.service not loaded.
Found global nodes: :
Reading package lists...
Building dependency tree...
Reading state information...
Package 'nodered' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Package 'nodejs-legacy' is not installed, so not removed
Package 'npm' is not installed, so not removed
Package 'nodejs' is not installed, so not removed
dpkg: warning: ignoring request to remove nodejs which isn't installed
dpkg: warning: ignoring request to remove node which isn't installed
/usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
/usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
- npm@6.7.0
added 52 packages from 7 contributors, removed 13 packages and updated 41 packages in 169.383s
npm WARN deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See Status :: Nodemailer
npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
npm WARN deprecated mimelib@0.3.1: This project is unmaintained
npm WARN deprecated mailcomposer@2.1.0: This project is unmaintained
npm WARN deprecated buildmail@2.0.0: This project is unmaintained
/usr/bin/node-red -> /usr/lib/node_modules/node-red/red.js
/usr/bin/node-red-pi -> /usr/lib/node_modules/node-red/bin/node-red-pi
bcrypt@2.0.1 install /usr/lib/node_modules/node-red/node_modules/bcrypt
node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v2.0.1/bcrypt_lib-v2.0.1-node-v64-linux-arm-glibc.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for bcrypt@2.0.1 and node@10.15.1 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
make: Entering directory '/usr/lib/node_modules/node-red/node_modules/bcrypt/build'
CXX(target) Release/obj.target/bcrypt_lib/src/blowfish.o
CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt.o
CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt_node.o
../src/bcrypt_node.cc: In function ‘char {anonymous}::ToCharVersion(v8::Localv8::String)’:
../src/bcrypt_node.cc:66:30: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
String::Utf8Value value(str);
In file included from /root/.node-gyp/10.15.1/include/node/v8.h:26:0,
from /root/.node-gyp/10.15.1/include/node/node.h:63,
from ../../nan/nan.h:51,
from ../src/bcrypt_node.cc:1:
/root/.node-gyp/10.15.1/include/node/v8.h:2892:28: note: declared here
explicit Utf8Value(Localv8::Value obj));
/root/.node-gyp/10.15.1/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
declarator attribute((deprecated(message)))
SOLINK_MODULE(target) Release/obj.target/bcrypt_lib.node
COPY Release/bcrypt_lib.node
COPY /usr/lib/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/lib/node_modules/node-red/node_modules/bcrypt/build'
- node-red@0.19.5
added 396 packages from 341 contributors in 288.193s
0.19.5
Installing extra nodes: node-red-node-random node-red-contrib-ibm-watson-iot node-red-node-ping node-red-contrib-play-audio node-red-node-smooth node-red-node-serialport :
serialport@6.2.2 install /home/pi/.node-red/node_modules/serialport
prebuild-install || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=10.15.1 runtime=node arch=arm platform=linux)
make: Entering directory '/home/pi/.node-red/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:41:49: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
v8::String::Utf8Value path(info[0]->ToString());
In file included from /home/pi/.node-gyp/10.15.1/include/node/v8.h:26:0,
from /home/pi/.node-gyp/10.15.1/include/node/node.h:63,
from ../../nan/nan.h:53,
from ../src/./serialport.h:6,
from ../src/serialport.cpp:1:
/home/pi/.node-gyp/10.15.1/include/node/v8.h:2892:28: note: declared here
/home/pi/.node-gyp/10.15.1/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
../src/serialport.cpp:48:53: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
v8::Localv8::Object options = info[1]->ToObject();
In file included from /home/pi/.node-gyp/10.15.1/include/node/node.h:63:0,
/home/pi/.node-gyp/10.15.1/include/node/v8.h:10046:15: note: declared here
Local Value::ToObject() const {
../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
../src/serialport.cpp:95:30: warning: ‘v8::Localv8::Value Nan::Callback::Call(int, v8::Localv8::Value) const’ is deprecated [-Wdeprecated-declarations]
data->callback.Call(2, argv);
In file included from ../src/./serialport.h:6:0,
../../nan/nan.h:1674:3: note: declared here
Call(int argc, v8::Localv8::Value argv[]) const {
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:113:53: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t)’:
../src/serialport.cpp:150:30: warning: ‘v8::Localv8::Value Nan::Callback::Call(int, v8::Localv8::Value) const’ is deprecated [-Wdeprecated-declarations]
data->callback.Call(1, argv);
../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t)’:
../src/serialport.cpp:188:30: warning: ‘v8::Localv8::Value Nan::Callback::Call(int, v8::Localv8::Value) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t)’:
../src/serialport.cpp:231:30: warning: ‘v8::Localv8::Value Nan::Callback::Call(int, v8::Localv8::Value) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:250:53: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t)’:
../src/serialport.cpp:285:30: warning: ‘v8::Localv8::Value Nan::Callback::Call(int, v8::Localv8::Value) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t)’:
../src/serialport.cpp:336:30: warning: ‘v8::Localv8::Value Nan::Callback::Call(int, v8::Localv8::Value) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t)’:
../src/serialport.cpp:383:30: warning: ‘v8::Localv8::Value Nan::Callback::Call(int, v8::Localv8::Value) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t)’:
../src/serialport.cpp:424:30: warning: ‘v8::Localv8::Value Nan::Callback::Call(int, v8::Localv8::Value) const’ is deprecated [-Wdeprecated-declarations]
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/poller.o
../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t, int, int)’:
../src/poller.cpp:69:29: warning: ‘v8::Localv8::Value Nan::Callback::Call(int, v8::Localv8::Value*) const’ is deprecated [-Wdeprecated-declarations]
obj->callback.Call(2, argv);
In file included from ../src/poller.cpp:1:0:
Call(int argc, v8::Localv8::Value argv) const {
CXX(target) Release/obj.target/serialport/src/serialport_linux.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
COPY Release/serialport.node
make: Leaving directory '/home/pi/.node-red/node_modules/serialport/build'
npm notice created a lockfile as package-lock.json. You should commit this file.
npm WARN node-red-project@0.0.1 No repository field.
npm WARN node-red-project@0.0.1 No license field.
- node-red-node-ping@0.0.16
- node-red-contrib-ibm-watson-iot@0.2.8
- node-red-node-random@0.1.2
- node-red-node-serialport@0.6.8
- node-red-contrib-play-audio@2.3.2
- node-red-node-smooth@0.1.0
added 273 packages from 125 contributors and audited 857 packages in 242.103s
found 0 vulnerabilities
The user pi' is already a member of gpio'.
Finished : Sun 10 Feb 13:47:10 GMT 2019
