Node-red not starting
I have node-red running on a Pine64 for a few months, a few days ago I had to reboot the Pine64 and now node-red won't start again.
Here is the console output after running node-red-start
Welcome to Node-RED
3 May 22:30:45 - [info] Node-RED version: v1.0.3
3 May 22:30:45 - [info] Node.js  version: v10.20.1
3 May 22:30:45 - [info] Linux 5.4.28-sunxi64 arm64 LE
3 May 22:30:47 - [info] Loading palette nodes
3 May 22:30:54 - [info] Dashboard version 2.19.4 started at /ui
3 May 22:30:55 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
3 May 22:30:55 - [warn] ------------------------------------------------------
3 May 22:30:55 - [warn] [node-red-contrib-homekit-bridged/homekit] Type already registered
3 May 22:30:55 - [info] Settings file  : /home/mustha/.node-red/settings.js
3 May 22:30:55 - [info] Context store  : 'default' [module=memory]
3 May 22:30:55 - [info] User directory : /home/mustha/.node-red
3 May 22:30:55 - [warn] Projects disabled : editorTheme.projects.enabled=false
3 May 22:30:55 - [info] Flows file     : /home/mustha/.node-red/flows_pine64.json
your credentials.
3 May 22:30:55 - [info] [GenericBLE] Start BLE scanning
3 May 22:30:55 - [info] Starting flows
3 May 22:30:56 - [red] Uncaught Exception:
3 May 22:30:56 - Error: ENODEV, No such device
    at Hci.init (/home/mustha/.node-red/node_modules/@abandonware/noble/lib/hci-socket/hci.js:100:35)
    at NobleBindings.init (/home/mustha/.node-red/node_modules/@abandonware/noble/lib/hci-socket/bindings.js:78:13)
    at process.nextTick (/home/mustha/.node-red/node_modules/@abandonware/noble/lib/noble.js:60:24)
    at process._tickCallback (internal/process/next_tick.js:61:11)
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
nodered.service: Service RestartSec=100ms expired, scheduling restart.
nodered.service: Scheduled restart job, restart counter is at 13.
Stopped Node-RED graphical event wiring tool.
I have tried so far to uninstall Homekit
npm uninstall node-red-contrib-homekit-bridged
and running audit
npm audit fix
no luck so far.
Thanks,
It appears to be caused by the noble node.
Thanks @bakman2 but it didn't work.
Here is the output of uninstalling noble
$ npm uninstall node-red-contrib-noble
> usb@1.6.3 install /home/mustha/.node-red/node_modules/usb
> prebuild-install --verbose || node-gyp rebuild
prebuild-install info begin Prebuild-install version 5.3.3
prebuild-install info looking for cached prebuild @ /home/mustha/.npm/_prebuilds/18e200-usb-v1.6.3-node-v64-linux-arm64.tar.gz
prebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v64-linux-arm64.tar.gz
prebuild-install http 404 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v64-linux-arm64.tar.gz
prebuild-install WARN install No prebuilt binaries found (target=10.20.1 runtime=node arch=arm64 libc= platform=linux)
make: Entering directory '/home/mustha/.node-red/node_modules/usb/build'
  CC(target) Release/obj.target/libusb/libusb/libusb/core.o
  CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
  CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
  CC(target) Release/obj.target/libusb/libusb/libusb/io.o
  CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
  CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
  CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
  CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
  CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
  CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
../libusb/libusb/os/linux_udev.c:40:10: fatal error: libudev.h: No such file or directory
 #include <libudev.h>
compilation terminated.
make: *** [libusb.target.mk:140: Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Error 1
make: Leaving directory '/home/mustha/.node-red/node_modules/usb/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! System Linux 5.4.28-sunxi64
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /home/mustha/.node-red/node_modules/usb
gyp ERR! node -v v10.20.1
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN node-red-project@0.0.1 No repository field.
npm WARN node-red-project@0.0.1 No license field.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 (node_modules/usb):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 install: `prebuild-install --verbose || node-gyp rebuild`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
audited 1132 packages in 47.618s
16 packages are looking for funding
  run `npm fund` for details
found 0 vulnerabilities
and after trying to start node-red yields the same result:
 node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.2.60:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use   node-red-stop                          to stop Node-RED
Use   node-red-start                         to start Node-RED again
Use   node-red-log                           to view the recent log output
Use   sudo systemctl enable nodered.service  to autostart Node-RED at every boot
Use   sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
4 May 08:25:26 - [info]
Welcome to Node-RED
4 May 08:25:26 - [info] Node-RED version: v1.0.3
4 May 08:25:26 - [info] Node.js  version: v10.20.1
4 May 08:25:26 - [info] Linux 5.4.28-sunxi64 arm64 LE
4 May 08:25:28 - [info] Loading palette nodes
4 May 08:25:38 - [info] Dashboard version 2.19.4 started at /ui
4 May 08:25:39 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
4 May 08:25:39 - [info] Settings file  : /home/mustha/.node-red/settings.js
4 May 08:25:39 - [info] Context store  : 'default' [module=memory]
4 May 08:25:39 - [info] User directory : /home/mustha/.node-red
4 May 08:25:39 - [warn] Projects disabled : editorTheme.projects.enabled=false
4 May 08:25:39 - [info] Flows file     : /home/mustha/.node-red/flows_pine64.json
your credentials.
4 May 08:25:39 - [info] [GenericBLE] Start BLE scanning
4 May 08:25:39 - [info] Starting flows
4 May 08:25:39 - [red] Uncaught Exception:
4 May 08:25:39 - Error: ENODEV, No such device
nodered.service: Scheduled restart job, restart counter is at 1.
From the output:
libudev.h is a header file that's part of the development package for libudev. I'm not sure if that's the issue, but further on it says that
Suggesting that it has indeed to do with udev. Can you try installing the development package for it through apt-get install libudev-dev, then retry the installation process?
It seems to be trying to rebuild the usb module. Try removing that
npm remove usb
Did you do something to your system that proor to the reboot? The ENODEV error seems rather odd.
I don't remember having installed any usb module. I did notice, though, that when I first tried to uninstall homekit-bridged it downloaded the the node-usb and tried to install it.
This is the output of the console when I tried to uninstall node-red-contrib-homekit-briged:
$ npm uninstall node-red-contrib-homekit-bridged
> usb@1.6.2 install /home/mustha/.node-red/node_modules/usb
prebuild-install info looking for cached prebuild @ /home/mustha/.npm/_prebuilds/7e1196-usb-v1.6.2-node-v64-linux-arm64.tar.gz
prebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.2/usb-v1.6.2-node-v64-linux-arm64.tar.gz
prebuild-install http 404 https://github.com/tessel/node-usb/releases/download/v1.6.2/usb-v1.6.2-node-v64-linux-arm64.tar.gz
gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.2 (node_modules/usb):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.2 install: `prebuild-install --verbose || node-gyp rebuild`
removed 6 packages and audited 1129 packages in 89.323s
found 13 low severity vulnerabilities
  run `npm audit fix` to fix them, or `npm audit` for details
$ npm audit fix
gyp ERR! not ok
> @abandonware/bluetooth-hci-socket@0.5.3-5 install /home/mustha/.node-red/node_modules/@abandonware/bluetooth-hci-socket
> node-pre-gyp install --fallback-to-build
node-pre-gyp WARN Using needle for node-pre-gyp https download
node-pre-gyp WARN Tried to download(404): https://github.com/abandonware/node-bluetooth-hci-socket/releases/download/0.5.3-5/binding-0.5.3-5-node-v64-linux-arm64.tar.gz
node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-5 and node@10.20.1 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
make: Entering directory '/home/mustha/.node-red/node_modules/@abandonware/bluetooth-hci-socket/build'
  CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
In file included from ../src/BluetoothHciSocket.cpp:8:
../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
In file included from /home/mustha/.cache/node-gyp/10.20.1/include/node/node_buffer.h:25,
                 from ../src/BluetoothHciSocket.cpp:7:
../src/BluetoothHciSocket.cpp: At global scope:
/home/mustha/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
       (node::addon_register_func) (regfunc),                          \
/home/mustha/.cache/node-gyp/10.20.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
../src/BluetoothHciSocket.cpp:578:1: note: in expansion of macro ‘NODE_MODULE’
 NODE_MODULE(binding, BluetoothHciSocket::Init);
In file included from /home/mustha/.cache/node-gyp/10.20.1/include/node/node.h:63,
/home/mustha/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
/home/mustha/.cache/node-gyp/10.20.1/include/node/node_object_wrap.h:84:78:   required from here
/home/mustha/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                reinterpret_cast<Callback>(callback), type);
/home/mustha/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
../../../nan/nan_object_wrap.h:65:61:   required from here
/home/mustha/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
  SOLINK_MODULE(target) Release/obj.target/binding.node
  COPY Release/binding.node
  COPY /home/mustha/.node-red/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node
  TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/home/mustha/.node-red/node_modules/@abandonware/bluetooth-hci-socket/build'
> @abandonware/noble@1.9.2-8 install /home/mustha/.node-red/node_modules/@abandonware/noble
> node-gyp rebuild
make: Entering directory '/home/mustha/.node-red/node_modules/@abandonware/noble/build'
  SOLINK_MODULE(target) Release/obj.target/noble.node
  COPY Release/noble.node
make: Leaving directory '/home/mustha/.node-red/node_modules/@abandonware/noble/build'
updated 9 packages in 125.847s
15 packages are looking for funding
fixed 13 of 13 vulnerabilities in 1129 scanned packages
I have tried @Colin suggestion first and since it didn't change anything I tried to follow @afelix suggestion (no installation problems there) and then retry to npm remove usb. Here is the console output:
$ npm remove usb
  AR(target) Release/obj.target/usb.a
  COPY Release/usb.a
  CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
In file included from ../src/helpers.h:3,
                 from ../src/node_usb.h:21,
                 from ../src/node_usb.cc:1:
../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../node_modules/nan/nan.h:2232:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
In file included from ../src/node_usb.h:14,
../src/node_usb.cc: At global scope:
/home/mustha/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
../src/node_usb.cc:95:1: note: in expansion of macro ‘NODE_MODULE’
 NODE_MODULE(usb_bindings, Initialize)
../src/node_usb.cc: In function ‘void handleHotplug(std::pair<libusb_device*, libusb_hotplug_event>)’:
../src/node_usb.cc:151:58: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
  Nan::MakeCallback(Nan::New(hotplugThis), "emit", 2, argv);
../node_modules/nan/nan.h:1001:46: note: declared here
   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
In file included from ../src/node_usb.h:12,
../node_modules/nan/nan_object_wrap.h:65:61:   required from here
  CXX(target) Release/obj.target/usb_bindings/src/device.o
                 from ../src/device.cc:1:
../src/device.cc: In member function ‘void Req::submit(Device*, v8::Local<v8::Function>, uv_work_cb, uv_work_cb)’:
../src/device.cc:220:70: warning: cast between incompatible function types from ‘uv_work_cb’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), &req, backend, (uv_after_work_cb) after);
../src/device.cc: In static member function ‘static void Req::default_after(uv_work_t*)’:
../src/device.cc:237:64: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
    Nan::MakeCallback(device, Nan::New(baton->callback), 1, argv);
../node_modules/nan/nan.h:959:46: note: declared here
  CXX(target) Release/obj.target/usb_bindings/src/transfer.o
                 from ../src/transfer.cc:1:
../src/transfer.cc: In function ‘void handleCompletion(Transfer*)’:
../src/transfer.cc:126:72: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
   Nan::MakeCallback(self->handle(), Nan::New(self->v8callback), 3, argv);
  SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
  COPY Release/usb_bindings.node
added 16 packages from 27 contributors and audited 1132 packages in 87.88s
What is this @ abandonware thing? This appears in all the errors and seems to be bluetooth related. I did install some bluetooth stuff as I was trying to see if I could connect to a Micro:bit.
I have managed to solve the problem after finding this thread with a similar issue.
After uninstalling generic-ble, with npm remove node-red-contrib-generic-ble, I was able to start node-red
Best
Are you saying that at some point you installed that node, then after that node-red ran fine for a few months until you rebooted, then it failed?
There is a change I might have forgot to restart node-red after having installed generic-ble, but it seems it did run but I can say for sure. In any case I can say node-red was running all that time for sure since it was posting the measurements of a sensor to influxdb.
cool - we like uptime !
