At last I have got this going.
For the benefit of others, this is what I did -
To understand it you must replace zzzzzzzzzzzz with your website url (this forum won't let me repeat url's)
I wanted it all to work below a subfolder of my site, so set up an iis site zzzzzzzzzzzz/xred
First just try 'hello world' in a .htm file to make sure iis is serving something at zzzzzzzzzzzz/xred/hello.htm
Then copy in hello.js and its web.config file from the iisnode examples and try zzzzzzzzzzzz/xred/hello.js to check iis + iisnode + node are all playing correctly together.
Now the hard part, to get node-red to work - this comes from an idea sparked by @TotallyInformation and the source of the azure implementation  node-red-azure-webapp on github, and a lot of looking at its result in an azure site I created with it.
- The stock install as per nodered.org/docs/platforms/windows is no good to you; Install node-red again NOT as a global module, in, or close to your new website.   I installed it in my /xred folder, so in a CMD box, something like:
cd C:\mywebsites\mysite\xred
npm install node-red
This creates a \xred\node_modules\ folder with all the node-red stuff in it.
I also created a folder tree at C:\mywebsites\nodered\.node-red\ for my userDir but this may not be necessary if it makes it itself on first run, but I wasn't sure (see settings.js below.)
\xred\server.js  This is a sort of wrapper for node-red to run in
var express = require("express");
var RED=require('node-red');
var app= express();
var http=require('http');
const PORT=process.env.PORT; //||8000;
var server=http.createServer(app);
var settings=require("./settings.js");
RED.init(server,settings);
app.use(settings.httpAdminRoot,RED.httpAdmin);
app.use(settings.httpNodeRoot,RED.httpNode);
server.listen(settings.uiPort);
console.log(`listening port:${settings.uiPort}`);
RED.start();
\xred\settings.js  (only important settings shown, everything else to your taste)
module.exports = {
    httpAdminRoot:"/xred/",
    httpNodeRoot: "/xred/",
    userDir:"../../nodered/.node-red/",
    uiPort: process.env.PORT, // || 8000
These 2 Root paths caused me a lot of hair pulling, if they're not exactly right then according to the logs node-red runs but all you get on screen is
cannot GET
which is something to do with express being finicky about paths.
\xred\web.config   More or less iisnode stock.
     This configuration file is required if iisnode is used to run node processes behind
     IIS or IIS Express.  For more information, visit:
     https://github.com/tjanczuk/iisnode/blob/master/src/samples/configuration/web.config
<configuration>
  <system.webServer>
    <webSocket enabled="false" />
    <handlers>
      <!-- Indicates that the server.js file is a node.js site to be handled by the iisnode module -->
       <add name="iisnode" path="server.js" verb="*" modules="iisnode" />
	  <!--<add name="iisnode" path="hello.js" verb="*" modules="iisnode"/>-->
    </handlers>
    <rewrite>
      <rules>
        <!-- Do not interfere with requests for node-inspector debugging-->
        <rule name="NodeInspector" patternSyntax="ECMAScript" stopProcessing="true">
          <match url="server.js\/debug[\/]?" />
        </rule>
        <!-- First we consider whether the incoming URL matches a physical file in the /public folder -->
        <rule name="StaticContent">
          <action type="Rewrite" url="public{PATH_INFO}" />
        </rule>
        <!-- All other URLs are mapped to the node.js site entry point-->
        <rule name="DynamicContent">
          <conditions>
            <add input="{REQUEST_FILENAME}" matchType="IsFile" negate="True" />
          </conditions>
          <action type="Rewrite" url="server.js" />
        </rule>
      </rules>
    </rewrite>
    <!-- 'bin' directory has no special meaning in node.js and apps can be placed in it -->
    <security>
      <requestFiltering>
        <hiddenSegments>
          <remove segment="bin" />
        </hiddenSegments>
      </requestFiltering>
    </security>
    <!-- Make sure error responses are left untouched -->
    <httpErrors existingResponse="PassThrough" />
      You can control how Node is hosted within IIS using the following options:
      See iisnode on github for a full list of options
    <iisnode watchedFiles="web.config;*.js" loggingEnabled="true" logDirectory="iisnode" debuggingEnabled="true" />
  </system.webServer>
</configuration>
- Now you should be able to navigate to www.mysite.com/xred and node-red will start.
If it says
Not started
I think this means it is re-starting after having detected a change in one of your iisnode watchedFiles , so just wait a bit and refresh the page - bob should be your uncle
I didn't get the special iisnode debug feature working as in zzzzzzzzzzzzzzzz/xred/hello.js/debug but it didn't work for me in the stock iisnode examples either - you just get a lot of uncaught syntax errors.
Protect your mode-red server with a password at least
iisnode exposes a folder zzzzzzzzzzzzzz/xred/iisnode/ with useful debug info but obviously rather insecure.  The recommendation is to change this folder name in iisnode settings to something very cryptic like a uuid
Richard
