Integer from a payload with the function node
NR receives a payload from a Seeed node that contains the light intensity in lux (image). The path of the decoded luminosity payload is:
payload.uplink_message.decoded_payload.messages[0].measurementValue
With a function node I only want to use an integer with the de lux value (as in example 4099) and I can't do that. The code below generates an error and as a beginner I wouldn't know how else to do it. Can someone help me with this?
var newMsg = { payload: payload.uplink_message.decoded_payload.messages[0].measurementValue };
return newMsg
NR
Just to the right of that 4099 value if you move the mouse there, a couple of icons appear.
One will look like >_
That copies the PATH.
Click on it then paste the value here.
Poor example of where this is.
Screenshot from 2023-02-24 19-26-17
Thanks for helping. The path is:
In the function node:
let x = msg.payload.uplink_message.decoded_payload.messages[0].measurementValue;
msg.payload = x;
I think that should work.
IF you don't want anything else from the message.
You solved my problem, thank you very much!
Glad I could help.
