Hello Everybody, I new in Node-red and I had a BMS Schneider ( EcoStruxure)
it's controller part number: (AS-P SmartX control) it is a Automation server with tcp/ip protocol
and http protocol.
I want to send orders from node red to the controller with
tcp/ip or http
I have tried to send package to it with tcp node
or post a order by http node and I failed
please anyone can help me
Any Help?!
...my crystal ball is dark.
Is there a specification of the BMS API, either for http or tcp/ip (maybe modbus protocol)?.
What did you try so far and what are the error responses you got?
Edit: ...looks like its a line of equipment using BacNet...did you check and try this ? -> node-red-contrib-bacnet (node) - Node-RED
flows.json (100.9 KB)
this is what I have tried so far
unfortunately, the protocol of master controller is TCP/IP
So I use wire shark to get certain package and I have tried to send the package using node red
I haven't get any response from the controller or any errors.
wiithout at least a hint of the underlying raw protocol I don't see a way to solve this easily.
Trying to hack into that thing and reverse engineering from wireshark logs is a strange way to go.
My assumption is, that the owner of that equipment is entitled to documentation (altough might not be allowed to share in public).
The only end-2-end protocol mentioned in the broshure is BacNet.
Edit: have you checked this: https://ecostruxure-building-help.se.com/bms/Topics/show.castle?id=9700&locale=en-US&productversion=3.2
Thank you for your reply.
yes I have checked the link.... but the controller act as master not a slave.
much appreciated for your help
