Hey all,
New Here. Quick question- I am looking to hit an API and it expects a Json of data. I am trying to write different parts of the payload to fields in the api call.
I know im doing something stupid - Any idea what it is?
Pete
You cannot use msg.xyz to insert values into a JSON type property.
One alternative is to use the Template node that does support that sort of value substitution.
What node is that
If you are just doing a HTTP request, you would simply populate msg.payload and pass that to the built in HTTP request node.
