Iot usb write problem
Im trying to write a csv in a usb at IOT2050, i mount the usb and try to send the csv with csv node and write file node but i get this error all time:
"failed to append to file: Error: EACCES: permission denied, open '/media/usb-drive/test.csv'
Someone knows what permission i need or how can i do to solve this?
Thanks in advanced.
Regards.
try to read a file from the usb first
or run as root or run this commende
chmod 666 /media/usb-drive/test.csv
Hi issambfs1,
I try but the same, permission denied.
When i mount the usb (sudo mount /dev/sdb1 /media/usb-drive) i cannt access to /media/usb-drive, permiss denied, if i umount the usb i can acces to /media/usb-drive.
So when usb is mounted i cannt access /media/usb-drive but if is umounted i can access/read/write at /media/usb-drive without problems.
I dont know where is the problem, im a little newby at ubuntu.
Having mounted it, what does this command show?
sudo ls -al /media/usb-drive
Hi Colin,
I have it, solved with :
sudo mount /dev/sda1 /media/usb-drive -o umask=000
Thank you!
