Is it possible to show the connected status icon of an MQTT Broker within a subflow to be available on the subflow node?
I have packed an mqtt in into a subflow and made it available to my container via the /data/flows.json
This makes the subflow nodes available in the node-palette upon boot up.
An example flow with the subflow node is:
the external mqtt in node has the following subflow template
It is just an mqtt in node configured to a fixed address and port.
I wish to get the connected status icon on the my external mqtt in "node", one similar to
The only thing I can see under my node even through adding status node in the subflow template is payload
Would this be possible to achieve with a subflow template?
  • Enable status
  • add a status node & point it at an MQTT node
  • wire the status node to status connector
NOTE: You might need to re-arrange the value out of the status node
