"Is Not A Valid Memory Write Message To Server"
I'm getting a bunch of numbers via Modbus TCP and am looking to rebroadcast those numbers via a node-red Modbus server, as below. However, I keep getting "Is Not A Valid Memory Write Message To Server" in the debug log on inputting these numbers. Related to this issue. Also for some reason the payload buffer is 48, despite only having 6 each of coils, holdings, inputs and discretes (24 total?)
        "id": "5d59c82badda5237",
        "type": "modbus-server",
        "z": "37f1be47da815ae1",
        "logEnabled": true,
        "hostname": "0.0.0.0",
        "serverPort": 10502,
        "responseDelay": 100,
        "delayUnit": "ms",
        "coilsBufferSize": "6",
        "holdingBufferSize": "6",
        "inputBufferSize": "6",
        "discreteBufferSize": "6",
        "showErrors": true,
        "x": 1520,
        "y": 1240,
                "d04855631aecc823"
        "id": "f5457920917eb0f0",
        "type": "switch",
        "property": "topic",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "gboiler_running_condition",
                "vt": "str"
                "t": "eq",
                "v": "gsilo_level_0_1000",
                "vt": "str"
                "t": "eq",
                "v": "gmax_stoker_speed",
                "vt": "str"
                "t": "eq",
                "v": "gpid_stoker_output",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 4,
        "x": 990,
        "y": 1040,
                "c396898e828dee2a"
                "4cefa7be49623107"
                "8512686ef7c21c3e"
                "62340306b6eaf6f0"
        "id": "b3fc5514304b5242",
        "type": "comment",
        "name": "Boiler Heat Meter kW & mWh [req. Serial RS485]",
        "info": "",
        "x": 200,
        "y": 960,
        "id": "290109b199a881e3",
        "type": "inject",
        "name": "Get Silo Level",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "5",
        "crontab": "",
        "once": true,
        "onceDelay": "1",
        "topic": "gsilo_level_0_1000",
        "payload": "",
        "payloadType": "date",
        "x": 140,
        "y": 1020,
                "889f040436167658"
        "id": "889f040436167658",
        "type": "link out",
        "name": "Sensors out",
        "mode": "link",
        "links": [
            "37db5198429b7396"
        "x": 405,
        "y": 1040,
        "id": "99eb4635c1919a85",
        "type": "link in",
        "name": "Processor in",
        "links": [
            "da25e4e66d04561c"
        "x": 705,
        "y": 1040,
                "134c7774ebcf3011"
        "id": "134c7774ebcf3011",
        "type": "modbus-flex-getter",
        "name": "Boiler_getter",
        "showStatusActivities": false,
        "showErrors": false,
        "showWarnings": true,
        "logIOActivities": false,
        "server": "d8b07ddb.c44d4",
        "useIOFile": false,
        "ioFile": "",
        "useIOForPayload": false,
        "emptyMsgOnFail": false,
        "keepMsgProperties": false,
        "delayOnStart": false,
        "startDelayTime": "",
        "x": 830,
        "y": 1040,
                "f5457920917eb0f0"
        "id": "4486d6e85a7d3e1b",
        "type": "comment",
        "name": "<-- I/O through lvc_labels -->",
        "info": "",
        "x": 560,
        "y": 1040,
        "id": "85ebfdbffa8d984b",
        "type": "debug",
        "name": "debug 10",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 1480,
        "y": 980,
        "id": "a28bbddf98fa5939",
        "type": "inject",
        "name": "Shutdown/Fireout",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "5",
        "crontab": "",
        "once": true,
        "onceDelay": "1",
        "topic": "gboiler_running_condition",
        "payload": "",
        "x": 150,
        "y": 900,
                "889f040436167658"
        "id": "4f9540eaeb13509a",
        "type": "inject",
        "name": "Stoker at maximum speed",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "5",
        "crontab": "",
        "once": true,
        "onceDelay": "1",
        "topic": "gmax_stoker_speed",
        "payload": "",
        "x": 160,
        "y": 1140,
                "889f040436167658"
        "id": "ad73abc4d0bad61d",
        "type": "inject",
        "name": "Averaged stoker speed",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "5",
        "crontab": "",
        "once": true,
        "onceDelay": "1",
        "topic": "gpid_stoker_output",
        "payload": "",
        "x": 150,
        "y": 1220,
                "889f040436167658"
        "id": "c396898e828dee2a",
        "type": "function",
        "name": "Shutdown/Fireout scale",
        "func": "msg.payload = msg.payload[0]/1;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1210,
        "y": 980,
                "85ebfdbffa8d984b",
                "5d59c82badda5237"
        "id": "4cefa7be49623107",
        "type": "function",
        "name": "Silo Level scale",
        "func": "msg.payload = msg.payload/10.0;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1180,
        "y": 1020,
                "8916057c5b4e9270",
                "5d59c82badda5237"
        "id": "8512686ef7c21c3e",
        "type": "function",
        "name": "Maximum stoker speed scale",
        "func": "msg.payload = msg.payload/1;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1220,
        "y": 1060,
                "ed36434616147015",
                "5d59c82badda5237"
        "id": "62340306b6eaf6f0",
        "type": "function",
        "name": "Averaged stoker speed scale",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1220,
        "y": 1100,
                "248c46681d071246",
                "5d59c82badda5237"
        "id": "c5a0fdf6b8bb9850",
        "type": "comment",
        "name": "[Unavailable] Stoker at minimum speed",
        "info": "",
        "x": 170,
        "y": 1080,
        "id": "8916057c5b4e9270",
        "type": "debug",
        "name": "debug 11",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 1480,
        "y": 1020,
        "id": "ed36434616147015",
        "type": "debug",
        "name": "debug 12",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1480,
        "y": 1060,
        "id": "248c46681d071246",
        "type": "debug",
        "name": "debug 13",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1480,
        "y": 1100,
        "id": "d04855631aecc823",
        "type": "debug",
        "name": "Server output",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "x": 1760,
        "y": 780,
        "id": "d8b07ddb.c44d4",
        "type": "modbus-client",
        "name": "Boiler_PLC",
        "clienttype": "tcp",
        "bufferCommands": true,
        "stateLogEnabled": false,
        "queueLogEnabled": false,
        "failureLogEnabled": false,
        "tcpHost": "192.168.127.2",
        "tcpPort": "502",
        "tcpType": "DEFAULT",
        "serialPort": "/dev/ttyUSB",
        "serialType": "RTU-BUFFERD",
        "serialBaudrate": "9600",
        "serialDatabits": "8",
        "serialStopbits": "1",
        "serialParity": "none",
        "serialConnectionDelay": "100",
        "serialAsciiResponseStartDelimiter": "",
        "unit_id": "1",
        "commandDelay": "1",
        "clientTimeout": "1000",
        "reconnectOnTimeout": true,
        "reconnectTimeout": "2000",
        "parallelUnitIdsAllowed": true
Debug log output:
alternating with
{"type":"holding","message":{"topic":"gsilo_level_0_1000","messageId":"644ac6d20671dce7f47d76ac","payload":70.2,"queueLengthByUnitId":{"unitId":255,"queueLength":2},"queueUnitId":255,"unitId":255,"modbusRequest":{"unitid":255,"fc":3,"address":105,"quantity":1,"emptyMsgOnFail":false,"keepMsgProperties":false,"messageId":"644ac6d20671dce7f47d76ac"},"responseBuffer":{"data":[702],"buffer":[2,190]},"_msgid":"649dc0709a39ce6f"},"payload":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"_msgid":"5d77a44cfc59b6dd"}
Your link does not work.
Oops, sorry - I must have copied it wrong: Questions about Modbus - UI controls and forwarding signals?
The original titular error message has now mysteriously disappeared with flow tidying my end; I suspect it may have been some malfunctioning experiment's output.
Now I'm getting a different error message:
"TypeError: Cannot read properties of undefined (reading 'length')"
Can anyone help?
Which node is throwing that error?
Seems to be the fireout node, which is giving value: undefined. Not sure why, as it's setup more or less the same as the other nodes. It will give different values depending on the power state, System Stopped/Loading/Starting/Running/Temperature/Stopping. Here's the annotated flow:
        "id": "3decb5f518882686",
        "type": "subflow",
        "name": "live debug",
        "info": "",
        "category": "",
        "in": [
                "x": 240,
                "y": 160,
                        "id": "45dbf990.ba2408"
        "out": [
                "x": 560,
                "y": 160,
                        "id": "45dbf990.ba2408",
                        "port": 1
        "env": [
                "name": "debug_name",
                "type": "str",
                "value": "Debug",
                "ui": {
                    "label": {
                        "en-US": "Name"
                    "type": "input",
                    "opts": {
                        "types": [
                            "str"
                "name": "debug_property",
                "type": "str",
                "value": "msg",
                "ui": {
                    "label": {
                        "en-US": "Property Path"
                    "type": "input",
                    "opts": {
                        "types": [
                            "str"
                "name": "pass_debug_property",
                "type": "bool",
                "value": "false",
                "ui": {
                    "label": {
                        "en-US": "Pass Property Path"
                    "type": "input",
                    "opts": {
                        "types": [
                            "bool"
        "meta": {},
        "color": "#DDAA99"
        "type": "function",
        "z": "3decb5f518882686",
        "name": "format time nicely",
        "func": "let msg1 = {payload: RED.util.cloneMessage(msg)};\nmsg1.payload.debug_property = msg.debug_property || env.get(\"debug_property\") || \"msg\"\ntry {\n  msg1.payload.debug_property_array = RED.util.normalisePropertyExpression(msg1.payload.debug_property)\n}\ncatch(error){\n  msg.payload = error;\n  msg1.payload.error = error;\n}\nmsg1.payload.debug_name = env.get(\"debug_name\") || msg._msgid || \"name error\"\nmsg1.payload.pass_debug_property = env.get(\"pass_debug_property\") || false\nreturn [msg1,msg];",
        "outputs": 2,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 390,
        "y": 120,
                "50da04b3.af25fc"
        "id": "50da04b3.af25fc",
        "type": "websocket out",
        "server": "985ecbc7.67a138",
        "client": "",
        "x": 680,
        "y": 120,
        "id": "1787be40.e87842",
        "type": "http in",
        "url": "/debug",
        "method": "get",
        "upload": false,
        "swaggerDoc": "",
        "x": 330,
        "y": 40,
                "1857548e.e7a8ab"
        "id": "1857548e.e7a8ab",
        "type": "template",
        "name": "Simple Web Page",
        "field": "payload",
        "fieldType": "msg",
        "format": "html",
        "syntax": "mustache",
        "template": "<!DOCTYPE HTML>\n<html>\n    <head>\n        <style>\n            span.debug_name {\n                color: black;\n            }\n            span.debug_error{\n                color: red;\n            }\n            span.debug_date{\n                color:blue;\n            }\n            pre[id^='json_data_']{\n                font-size:20px;\n                background-color: ghostwhite;\n                border: 1px solid silver;\n                padding: 10px 20px;\n                margin: 20px; \n                white-space: pre-wrap;\n            }\n            .json-key {\n                color: olive;\n            }\n            .json-value {\n                color: navy;\n            }\n            .json-string {\n                color: brown;\n            }\n\n        </style>\n    <title>Debug Messages</title>\n    <script type=\"text/javascript\">\n        var ws;\n        var wsUri = \"ws:\";\n        var loc = window.location;\n        console.log(loc);\n        if (loc.protocol === \"https:\") { wsUri = \"wss:\"; }\n        // This needs to point to the web socket in the Node-RED flow\n        wsUri += \"//\" + loc.host + loc.pathname.replace(\"debug\",\"ws/debug\");\n\n        function wsConnect() {\n            console.log(\"connect\",wsUri);\n            ws = new WebSocket(wsUri);\n            ws.onmessage = function(msg) {\n                segments = document.getElementById('json_data').innerHTML;\n                var paused = document.getElementById('paused').innerText === \"Pause\";\n                var data;\n                var line = \"\";\n                var error = \"\";\n                var date = new Date().toISOString();\n                // parse the incoming message as a JSON object\n                try { \n                    data = JSON.parse(msg.data);\n                } catch (json_error) {\n                    data = {error: [\"json parse error\", json_error]};\n                };   \n                if(!data.error){\n                    var debug_name = data.debug_name ;\n                    var debug_property = data.debug_property_array;\n                    var original_property = data.debug_property;\n                    if(!data.pass_debug_property) delete data.debug_property;\n                    delete data.pass_debug_property;\n                    delete data.debug_property_array;\n                    delete data.debug_name;\n                    debug_property.slice(1).forEach((prop, index) => {\n                        if(data[prop]) {                    \n                            data = data[prop];\n                        }else{\n                           error = \"Property path Error on or after - \" + debug_property[index];\n                        }\n                    });\n\n                    line = `<div id=\"element${date}\">\n                    <hr/>\n                    <span class=\"debug_name\">${debug_name}</span> <span class=\"debug_date\">${date}</span> \n                    <span class=\"debug_orginal\">${original_property}</span> <span class=\"debug_error\">${error}</span> \n                     <button title=\"copy\" alt=\"copy\" onclick=\"copy_text('json_data_${date}')\"> &#10066; </button>\n                    <button title=\"delete\" alt=\"delete\" onclick=\"delete_text('element${date}')\"> &#10060; </button> \n                    <span class=\"json_data\">\n                    <pre id=\"json_data_${date}\"><code id=data>${library.json.prettyPrint(data)}</code></pre></span> \n                    </div>`;\n                }else{\n                    line = `<div id=\"element${date}\">\n                    <hr/>\n                    <span class=\"debug_error\">Error: ${JSON.stringify(data.error)}</span> <span class=\"debug_date\">${date}</span>                  \n                    <button title=\"delete\" alt=\"delete\" onclick=\"delete_text('element${date}')\"> &#10060; </button> \n                    </div>`;\n                }\n            // append line to segment\n            if(paused){\n                document.getElementById('json_data').innerHTML = line + segments;\n            }\n            }\n            ws.onopen = function() {\n                // update the status div with the connection status\n                document.getElementById('status').innerHTML = \"connected\";\n                //ws.send(\"Open for data\");\n                console.log(\"connected\");\n            }\n            ws.onclose = function() {\n                // update the status div with the connection status\n                document.getElementById('status').innerHTML = \"not connected\";\n                // in case of lost connection tries to reconnect every 3 secs\n                setTimeout(wsConnect,3000);\n            }\n        }\n        function copy_text(input) {\n            // Get the text field\n            var copyText = document.getElementById(input).innerText;\n            var dummy = document.createElement(\"textarea\");\n            document.body.appendChild(dummy);\n            dummy.value = copyText;\n            dummy.select();\n            document.execCommand(\"copy\");\n            document.body.removeChild(dummy);\n            alert(\"Copied  Data to Clipboard\\n\\n\" + copyText)\n        }\n        function delete_text(input) {\n            // Get the text field\n            document.getElementById(input).innerHTML = \"\";\n        }\n        if (!library) var library = {};\n            library.json = {\n                replacer: function(match, pIndent, pKey, pVal, pEnd) {\n                    var key = '<span class=json-key>\"';\n                    var val = '<span class=json-value>';\n                    var str = '<span class=json-string>';\n                    var r = pIndent || '';\n                    if (pKey)\n                        r = r + key + pKey.replace(/[\": ]/g, '') + '\"</span>: ';\n                    if (pVal)\n                        r = r + (pVal[0] == '\"' ? str : val) + pVal + '</span>';\n                        return r + (pEnd || '');\n                    },\n                    prettyPrint: function(obj) {\n                        var jsonLine = /^( *)(\"[\\w]+\": )?(\"[^\"]*\"|[\\w.+-]*)?([,[{])?$/mg;\n                        return JSON.stringify(obj, null, 4)\n                            .replace(/&/g, '&amp;').replace(/\\\\\"/g, '&quot;')\n                            .replace(/</g, '&lt;').replace(/>/g, '&gt;')\n                            .replace(jsonLine, library.json.replacer);\n                    }\n                    \n                };\n        function pause() {\n            var element_paused = document.getElementById(\"paused\");\n            paused = (element_paused.innerText === \"Resume\") ? \"Pause\" : \"Resume\";\n            element_paused.innerText = paused;\n        }\n    \n    </script>\n    </head>\n    <body onload=\"wsConnect();\" onunload=\"ws.disconnect();\">\n        <font face=\"Arial\">\n        <h1>Debug Messages <button id=\"paused\" value=\"pause\" onclick=\"pause()\">Pause</button> </h1>\n        <div id=\"json_data\"></div>\n        <hr/>\n        <div id=\"status\">unknown</div>\n        </font>\n    </body>\n</html>\n",
        "x": 550,
        "y": 40,
                "42a28745.bd5d78"
        "id": "42a28745.bd5d78",
        "type": "http response",
        "x": 730,
        "y": 40,
        "id": "985ecbc7.67a138",
        "type": "websocket-listener",
        "path": "/ws/debug",
        "wholemsg": "false"
        "id": "37f1be47da815ae1",
        "type": "tab",
        "label": "Modbus Server",
        "disabled": false,
        "info": "",
        "env": []
        "id": "49c18e3ad19acbda",
        "type": "group",
        "style": {
            "stroke": "#999999",
            "stroke-opacity": "1",
            "fill": "none",
            "fill-opacity": "1",
            "label": true,
            "label-position": "nw",
            "color": "#a4a4a4"
        "nodes": [
            "c5a0fdf6b8bb9850",
            "ed36434616147015",
            "248c46681d071246",
            "62340306b6eaf6f0",
            "f5457920917eb0f0",
            "8512686ef7c21c3e",
            "4cefa7be49623107",
            "c396898e828dee2a",
            "85ebfdbffa8d984b",
            "8916057c5b4e9270",
            "5d59c82badda5237",
            "d04855631aecc823",
            "3acabffc83517f90",
            "134c7774ebcf3011",
            "4486d6e85a7d3e1b",
            "889f040436167658",
            "99eb4635c1919a85",
            "b3fc5514304b5242",
            "a28bbddf98fa5939",
            "290109b199a881e3",
            "4f9540eaeb13509a",
            "ad73abc4d0bad61d"
        "x": 14,
        "y": 159,
        "w": 1932,
        "h": 444.5
        "g": "49c18e3ad19acbda",
        "logEnabled": true,
        "delayUnit": "ms",
        "showErrors": true,
        "x": 1560,
        "y": 540,
                "d04855631aecc823",
                "3acabffc83517f90"
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1820,
        "y": 440,
        "type": "switch",
        "rules": [
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 4,
        "x": 1030,
        "y": 340,
                "c396898e828dee2a"
                "4cefa7be49623107"
                "8512686ef7c21c3e"
                "62340306b6eaf6f0"
        "type": "comment",
        "info": "",
        "x": 240,
        "y": 260,
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "5",
        "crontab": "",
        "once": true,
        "onceDelay": "1",
        "payload": "",
        "x": 180,
        "y": 320,
                "889f040436167658"
        "type": "link out",
        "mode": "link",
        "links": [
            "37db5198429b7396"
        "x": 445,
        "y": 340,
        "type": "link in",
        "links": [
            "da25e4e66d04561c"
        "x": 745,
        "y": 340,
                "134c7774ebcf3011"
        "useIOFile": false,
        "ioFile": "",
        "x": 870,
        "y": 340,
                "f5457920917eb0f0"
        "type": "comment",
        "info": "",
        "x": 600,
        "y": 340,
        "type": "debug",
        "name": "debug 10",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1520,
        "y": 280,
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "5",
        "crontab": "",
        "once": true,
        "onceDelay": "1",
        "payload": "",
        "x": 190,
        "y": 200,
                "889f040436167658"
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "5",
        "crontab": "",
        "once": true,
        "onceDelay": "1",
        "payload": "",
        "x": 200,
        "y": 440,
                "889f040436167658"
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "5",
        "crontab": "",
        "once": true,
        "onceDelay": "1",
        "payload": "",
        "x": 190,
        "y": 520,
                "889f040436167658"
        "type": "function",
        "name": "[ERROR] Shutdown/Fireout scale",
        "func": "// This node causes \"TypeError: Cannot read properties of undefined (reading 'length')\"\nmsg.payload = msg.payload[0]/1;\n\nmsg.payload = { 'value': msg.payload[0],\n 'register': 'holding',\n  'address': 1,\n  'disableMsgOutput': 0 };\n   \n return msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1280,
        "y": 280,
                "85ebfdbffa8d984b"
        "type": "function",
        "func": "msg.payload = {\n    'value': msg.payload,\n    'register': 'holding',\n    'address': 2,\n    'disableMsgOutput': 0\n};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1220,
        "y": 320,
                "8916057c5b4e9270",
                "5d59c82badda5237"
        "type": "function",
        "func": "msg.payload = {\n    'value': msg.payload,\n    'register': 'holding',\n    'address': 3,\n    'disableMsgOutput': 0\n};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1260,
        "y": 360,
                "ed36434616147015",
                "5d59c82badda5237"
        "type": "function",
        "func": "msg.payload = {\n    'value': msg.payload,\n    'register': 'holding',\n    'address': 4,\n    'disableMsgOutput': 0\n};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1260,
        "y": 400,
                "248c46681d071246",
                "5d59c82badda5237"
        "type": "comment",
        "info": "",
        "x": 190,
        "y": 380,
        "type": "debug",
        "name": "debug 11",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1520,
        "y": 320,
        "type": "debug",
        "name": "debug 12",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1500,
        "y": 360,
        "type": "debug",
        "name": "debug 13",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1500,
        "y": 400,
        "id": "3acabffc83517f90",
        "type": "subflow:3decb5f518882686",
        "x": 1830,
        "y": 540,
        "id": "c1f1279b6bad34ee",
        "type": "comment",
        "name": "Brown & Carroll Modbus re-server",
        "info": "",
        "x": 920,
        "y": 100,
        "tcpPort": "502",
        "unit_id": "1",
You have this code in that function
The first line sets msg.payload to whatever is in msg.payload[0], though I don't know why you are dividing it by 1. After that line is executed msg.payload is no longer an array. In the second line you are trying to pick up msg.payload[0] again, but it is no longer an array. Perhaps you meant
msg.payload = {value: msg.payload,
If the purpose of dividing by 1 is to convert it from a string to a number then you can remove the first line, and in the second line use
msg.payload = { 'value': Number(msg.payload[0]),
That seems to have fixed it; thank you so much!
The division by 1 is a mysterious artifact inherited from legacy code; your archaeology skills are much better than mine, and your interpretation makes sense as well as banishing the error I was having.
By the way, in javascript, if object properties do not contain special characters such as - or space then you don't need to include them in quotes, so you could save a bit of typing and use
msg.payload = {value: Number(msg.payload[0]),
  register: 'holding',
  address: 1,
  disableMsgOutput: 0
If you are writing JSON then you do need the quotes.
