Is there a Node Palette for QuestDB?
i have switched form InfluxDB to QuestDB, is there a Node Palette to write into QuestDB like the InfluxDB Node ?
I don't believe there is, but you can use the nodejs client package, by importing it in a function node.
In the On Message tab you can use it like:
const {Sender} =  questDb
const conf = "http::addr=localhost:9000;username=admin;password=quest;"
const sender = Sender.fromConfig(conf);
node.warn({payload:sender})
It will install the package the first time you deploy it (the nodes will be non-interactive while it is installing)
