Is there any input date and time for node edit dialog?
Hi all,
Moreover, can we use JQuery UI in node edit dialog?
:thinking:
Because HTML does not support all browser.
Thank you very much in advance
There is not a node-red core date picker widget.
Yes, the editor uses JQuery UI
Thank you very much :blush: :+1:
I can use directly JQuery UI datepicker (not include anything) in my created node.
Are the browser native components not sufficient? I believe all modern browsers have date and time input fields.
Thank you very much for your reply. :slightly_smiling_face:
I have one more question. Does JQuery UI have 'Time Picker' widget? Because I separate 'Time' input from 'Date'.
I try to search about 'Time Picker' in JQuery UI. Some website tell, it has to use 'timepicker'. But I try to use in edit dialog, the error 'timepicker is not a function ...'. :thinking:
Could you please advise me?
The website is quite clear: Datepicker | jQuery UI
No timepicker.
Would standard html5 input text box in time mode work ?
Thank you very much for your advise.
But old browser maybe not support html5. So now I use simple input and then using validate input time. :blush:
Looks pretty well supported - apart from IE of course... (which is now past end of life.)
The Node-RED editor will not work in those older browsers.
You can always add a polyfill for older/rubbish browsers:
https://www.google.com/search?q=polyfil+for+input+type%3Dtime
Ok. I will try to use HTML5 tag input time.
Thank you very much for your help. :blush: :+1:
I will try this.
