I tested adding msg.payload values in the gauge ( {{value}} ) this seems to work on the label, units and value format. but not on the range perimeter. is their any way ?
Those parameters can be changed by using msg.ui_control property
See this document https://github.com/node-red/node-red-dashboard/blob/master/config-fields.md
thanks ! just what i needed
