Hello, i currently learning how to inject historical data into MQTT but no luck so far. The data is only being updated every hours and i only learn how to inject the current hour's data. I wanted to inject past 23 hours (follow by hours) to create a graph and table.
I am currently using Node-RED 2
the data in wanted to combine
with
what i current done so far :
"id": "fe4a8be1e2cfcf9c",
"type": "tab",
"label": "Assignment - Mini Project",
"disabled": false,
"info": "",
"env": []
"id": "756eed0ccabf585f",
"type": "inject",
"z": "fe4a8be1e2cfcf9c",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 120,
"y": 100,
"e07b34fecc5dc172"
"id": "e07b34fecc5dc172",
"type": "http request",
"method": "GET",
"ret": "obj",
"paytoqs": "ignore",
"url": "http://apims.doe.gov.my/data/public_v2/CAQM/last24hours.json",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"senderr": false,
"x": 290,
"y": 100,
"6471c2fa28c5082b",
"b882f143cd9b3ef6",
"cc13d957a1b638fc"
"id": "f955a43de3a266a5",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1350,
"y": 100,
"id": "b882f143cd9b3ef6",
"type": "function",
"func": "time = msg.payload[\"24hour_api_apims\"][0][25]\nAPI = msg.payload[\"24hour_api_apims\"][40][25]\nmsg.topic = \"API\"\nmsg.payload = time + \" \" + API\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 500,
"y": 200,
"589894decea145ca"
"id": "6471c2fa28c5082b",
"type": "debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 510,
"y": 80,
"id": "cc13d957a1b638fc",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "$now()",
"tot": "jsonata"
"t": "set",
"p": "topic",
"pt": "msg",
"to": "timestamp",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 520,
"y": 140,
"id": "f20c30298dd08d3c",
"type": "join",
"mode": "custom",
"build": "object",
"property": "payload",
"propertyType": "msg",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": false,
"timeout": "",
"count": "2",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 990,
"y": 160,
"00e2f9f131bea172"
"id": "00e2f9f131bea172",
"type": "json",
"action": "str",
"pretty": false,
"x": 1150,
"y": 160,
"f955a43de3a266a5",
"3a8a40cb7c4b4071"
"id": "3a8a40cb7c4b4071",
"type": "mqtt out",
"topic": "1905583/mypi/topic1",
"qos": "0",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "e24538a1220d8976",
"x": 1380,
"y": 160,
"id": "a390f917b6627426",
"type": "function",
"func": "let array = (msg.payload[0]*3600000)\nreturn msg\n\n\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 460,
"y": 300,
"1471df19b0c580e5"
"id": "4b6194e258e8c688",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"x": 260,
"y": 300,
"a390f917b6627426",
"db3ec0040b3579e9"
"id": "1471df19b0c580e5",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 610,
"y": 300,
"id": "db3ec0040b3579e9",
"type": "function",
"func": "let past = msg.payload -(3600) * 1000\nlet pastday = new Date(past).toLocaleString(\"en-US\");\npastday = pastday.replace(\",\",\"\"); // OPTIONAL Remove Commas\nmsg2 = {payload: pastday};\nreturn msg2",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 440,
"y": 400,
"id": "118854456cec17b8",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "$now()",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 480,
"y": 340,
"id": "589894decea145ca",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 810,
"y": 160,
"id": "e24538a1220d8976",
"type": "mqtt-broker",
"name": "Hivemq UCCN2513",
"broker": "broker.hivemq.com",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
