dear all,
since 2 days, I have an issue with my not red, all was working fine before but now I fixed to an issue and I need your help
In copy the log and error I have:
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
9 Oct 17:32:24 - [info]
Welcome to Node-RED
9 Oct 17:32:24 - [info] Node-RED version: v1.0.1
9 Oct 17:32:24 - [info] Node.js version: v10.16.3
9 Oct 17:32:24 - [info] Linux 4.19.57-v7+ arm LE
9 Oct 17:32:27 - [info] Loading palette nodes
9 Oct 17:32:36 - [info] Dashboard version 2.16.2 started at /ui
9 Oct 17:32:37 - [info] Settings file : /home/pi/.node-red/settings.js
9 Oct 17:32:37 - [info] Context store : 'default' [module=memory]
9 Oct 17:32:37 - [info] User directory : /home/pi/.node-red
9 Oct 17:32:37 - [warn] Projects disabled : editorTheme.projects.enabled=false
9 Oct 17:32:37 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
your credentials.
9 Oct 17:32:37 - [info] Starting flows
9 Oct 17:32:37 - [info] [blynk-ws-client:temperature] LOG PINS []
9 Oct 17:32:37 - [info] [blynk-ws-client:temperature] Start connection: ws://blynk-cloud.com/websockets
9 Oct 17:32:37 - [info] [blynk-ws-client:25b385e5.f5f19a] LOG PINS []
9 Oct 17:32:37 - [info] [blynk-ws-client:25b385e5.f5f19a] Start connection: ws://blynk-cloud.com/websockets
9 Oct 17:32:37 - [info] Started flows
9 Oct 17:32:37 - [info] Server now running at http://127.0.0.1:1880/
9 Oct 17:32:37 - [info] [blynk-ws-client:temperature] Client logged
9 Oct 17:32:37 - [info] [blynk-ws-client:25b385e5.f5f19a] Client logged
9 Oct 17:32:38 - [info] [ttn app:c3c68d.72b1597] Connected to TTN application esp32-ttgo
9 Oct 17:32:43 - [red] Uncaught Exception:
9 Oct 17:32:43 - Error: Connection refused: Not authorized
at MqttClient._handleConnack (/home/pi/.node-red/node_modules/mqtt/lib/client.js:920:15)
at MqttClient._handlePacket (/home/pi/.node-red/node_modules/mqtt/lib/client.js:350:12)
at work (/home/pi/.node-red/node_modules/mqtt/lib/client.js:292:12)
at Writable.writable._write (/home/pi/.node-red/node_modules/mqtt/lib/client.js:302:5)
at doWrite (/home/pi/.node-red/node_modules/readable-stream/lib/_stream_writable.js:428:64)
at writeOrBuffer (/home/pi/.node-red/node_modules/readable-stream/lib/_stream_writable.js:417:5)
at Writable.write (/home/pi/.node-red/node_modules/readable-stream/lib/_stream_writable.js:334:11)
at Socket.ondata (_stream_readable.js:709:20)
at Socket.emit (events.js:198:13)
at addChunk (_stream_readable.js:288:12)
at readableAddChunk (_stream_readable.js:269:11)
at Socket.Readable.push (_stream_readable.js:224:10)
at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
nodered.service: Service RestartSec=100ms expired, scheduling restart.
nodered.service: Scheduled restart job, restart counter is at 1.
Stopped Node-RED graphical event wiring tool.
